The Official 99-00 Civic Intercooler + Foglights Thread
Old 03-15-2006, 09:09 AM
Buzzbomb's Avatar
Default The Official 99-00 Civic Intercooler + Foglights Thread
Post em up!
Along with your pics, please post the following:
Type of piping kit: Brand name, custom, piping size, etc.
Intercooler brand:
Intercooler size:
What modifications you made to fit the fogs:
Now for me,
Type of piping kit: Greddy kit with Greddy piping. 2" inlet 2 1/4" outlet
Intercooler brand: Treadstone intercooler.
Intercooler size: 28”x6” overall
Modifications:
Passenger’s side. Long support bracket cut. Back bracket on foglight cut to clear the charge pipe. The pipe slopes down and clears the foglight housing. Fits very well.
Driver’s side. Long support bracket cut. Back bracket on foglight cut, as well as a notch cut out of the foglight housing. Illustrated as such:
After I cut out the housing, the inside was exposed, so I filled it in with Hondabond. In order to get the foglight in the correct position, I had to push down on the pipe and tighten down the screws to hold it in place. It is very tight and there is no freeplay.
I may re-do it with a custom pipe, but I’m going to see how this works for now. Custom piping is expensive.
EDIT: Recently I had the bumper off and decided to re-do the piping since the driver's side pipe was still hitting the housing and causing the fog light garnish to bulge out. I was able to lower the intercooler approximately 1 inch and trimmed the fender liner accordingly. The piping now sits low enough that it completely clears the fog housing. If I wanted I could get a new, un notched housing to replace mine. Why didn't I do this before? I wanted the intercooler to sit against the bumper beam for maximum exposure in the grill and to create a pressure differential. Now I want it to fit right.
Modified by Buzzbomb at 8:01 PM 4/28/2008
Old 03-15-2006, 09:24 AM
EK k kay's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (Buzzbomb)
Good stuff.
I was thinking maybe mount the intercooler a little lower so your ic pipes wouldn't have to angle downward so much?
Old 03-15-2006, 09:52 AM
Buzzbomb's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Good stuff.
I was thinking maybe mount the intercooler a little lower so your ic pipes wouldn't have to angle downward so much?</TD></TR></TABLE>
Believe me, I tried. The passenger side pipe is hitting the splash guard already and I could have lowered the drivers side more, but that would give me a real ****-eyed intercooler and would have looked goofy.
Old 03-15-2006, 12:33 PM
igo4bmx's Avatar
lets see the full front end in a single pic
Old 03-15-2006, 12:44 PM
bluemax189's Avatar
Default Re: (igo4bmx)
im going to have to go home now and try this. i had fogs, then had to take them out.
Old 03-15-2006, 01:43 PM
Unsivil_audio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Are your foglights OEM? Do you normally have to cut big *** holes like that in the bumper to install fog lights?
Old 03-15-2006, 01:58 PM
JDM_EM1's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio &raquo;</TD></TR><TR><TD CLASS="quote">
Are your foglights OEM? Do you normally have to cut big *** holes like that in the bumper to install fog lights? </TD></TR></TABLE>
yea u do have to cut a big *** hole like that for fogs, thanks for the tips im gonna do this when im rdy to start installing my turbo ****
Old 03-15-2006, 02:09 PM
DaveF's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (JDM_EM1)
2.5inch piping
23x11x3.5 spearco
back door on driver side/ outlet on bottom of the tank(pass)
cut the long leg off the fog light bracket.
here is my car. just got done building it last week. i custom made the intecooler piping. JM fab welded it all for me. i also had the outlets moved down on my end tanks.
all i have for now. i will get a few more shots soon enough.
Modified by Dturbocivic at 6:48 AM 3/16/2006
Modified by Dturbocivic at 6:49 AM 3/16/2006
Old 03-15-2006, 02:38 PM
Mr. Vapor's Avatar
intercooler: DRAG/Spearco
Piping: DRAG
Modifications: Had to cut the lower bracket off of the fog light housing.
new set up will be a 24x12x3 so im not sure how the expletive im going to pull this one off......
Old 03-15-2006, 02:42 PM
96ex's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (Dturbocivic)
I used an SRT4 intercooler(double backdoor endtanks). I had to remove the bumper bar to get it to fit.
But using and SRT4 intercooler shaved me loads on the cost of intercooler piping.
Compressor outlet is attached directly to the Intercooler inlet. And I don't have to route my piping all over the place to reach the throttle body.
Old 03-15-2006, 02:47 PM
Mr. Vapor's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (96ex)
yea a backdoor FMIC would make things so much easier.
Old 03-15-2006, 04:02 PM
SPOON_BeIgHtEeNsEe's Avatar
Type of piping kit: crp, custom, 2.5
Intercooler size:30x12x3
What modifications you made to fit the fogs: flipped the IC upside down... and removed bumper support... dont have pic yet... but will have some up shortly...
Old 03-16-2006, 04:40 AM
Buzzbomb's Avatar
You obvioulsy didn't notice the very first pic with the foglight and garnish in to see that it's all trimmed out?
Yes they are OEM, and yes, as stated before, you do have to cut a hole that big. The hole is even outlined on the back of the bumper.
MORE PICS!!
Old 03-19-2006, 08:09 AM
Buzzbomb's Avatar
Add your pics if you got them.
Old 07-24-2006, 07:27 PM
Danethomp's Avatar
good thread
Old 04-26-2007, 08:44 AM
Buzzbomb's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (Danethomp)
Anyone else with pics?
Old 04-26-2007, 09:46 PM
BuiltforSin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else with pics?</TD></TR></TABLE>
x2
Old 04-26-2007, 11:56 PM
Snake Eyes's Avatar
Type of piping kit: GReddy piping included with intercooler.
Intercooler brand: GReddy 31V Intercooler.
Intercooler size: 195mm x 600mm x 76mm
Old 04-27-2007, 04:05 AM
i my honda
Global Mod
White Smoke's Avatar
Here is Jason's aka: Blown90hatcH
He has the intercooler mounted upside down and there is no support so it makes it allot easier!
You guys should also note if you have traction bars or not
Old 02-10-2008, 12:05 AM
NooB
IT'S ME DAVID's Avatar
OK I have a top mount t4 turbo that has made 600 whp on my EG.Now Im going to take out the swap and put it on my 00 ek hb But I have a spearco big intercooler 32x10.5x3 So my Question is will this fit my ek using custom 2.5" intercooler piping and not have to cut up my bumper.Also can i retain my stock foglights also.Thanks in advance.
Old 02-10-2008, 07:37 PM
NooB
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (IT'S ME DAVID)
Old 02-10-2008, 07:44 PM
mrbsponge's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Here is Jason's aka: Blown90hatcH
You guys should also note if you have traction bars or not </TD></TR></TABLE>
Jasons car DOES have a traction bar yeah he had to work to get it all in there well but it looks so nice, the intercooler is flipped and it made everything in the front end look so much nicer
Old 02-11-2008, 05:01 AM
Blown90hatcH's Avatar
Default Re: The Official 99-00 Civic Intercooler + Foglights Thread (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">Jasons car DOES have a traction bar yeah he had to work to get it all in there well but it looks so nice, the intercooler is flipped and it made everything in the front end look so much nicer</TD></TR></TABLE>
Bigger intercooler and 3" charge piping coming soon. Still keep the fogs too.
Old 03-26-2008, 06:09 AM
steveo2000em1's Avatar
Anybody else have pics to post?
Old 03-26-2008, 07:42 AM
norcalbayboy's Avatar
3 inch piping with huge front mount intercooler
Quick Reply: The Official 99-00 Civic Intercooler + Foglights Thread
