injector/drivability question!
Old Mar 14, 2006 | 11:25 AM
4inspeed's Avatar
Default injector/drivability question!
right now im running a fmu/missing link on my eg single cam turbo, runing only 6 psi..
i have a walbro 255 already installed.. my question is basically if i stick in the rc 550's i have and take out the fmu/missing link will the car run well enough to get me to the tunnig shop? its not close by any means and i will probably hit alot of stop and go and open highway driving...
just want to make sure the car will not f*ck up on me untill i get to tune it..
Old Mar 14, 2006 | 01:02 PM
turboEGhatch's Avatar
Default Re: injector/drivability question! (4inspeed)
I would never do that. Your motor is going to be seeing more than twice as much fuel as it is used to, you're going to be running at like a 7:1 air/fuel ratio.
Worst case scenario? You could get so much fuel in your oil that you ruin it's lubricating properties and you eat up your bearings and need to rebuild your motor. Injectors arn't that hard to install, drive there on stockers and install the new ones when you get to the place, or get the ECU chipped with a 550CC basemap ahead of time.
Old Mar 14, 2006 | 01:07 PM
s2kdre's Avatar
Default Re: injector/drivability question! (turboEGhatch)
just swap them out at the dyno, its only a 5min job,
Old Mar 14, 2006 | 01:14 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: injector/drivability question! (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">just swap them out at the dyno, its only a 5min job,</TD></TR></TABLE>
ditto. my tuning place is 60 miles away. I just drive there on stock injectors it will be ok just don't boost drive normal. half throttle everything
Old Mar 14, 2006 | 02:34 PM
D@nnY's Avatar
the car may not even start on the 550s and it will ruin the motor if it does ...
Old Mar 14, 2006 | 03:44 PM
4inspeed's Avatar
Default Re: (D@nnY)
thanks... thats what i thought just making sure...
00BoostedGSR
Sep 25, 2007 07:07 AM
Niskyspy
Nov 19, 2006 06:59 PM
Slow Ek
Aug 16, 2006 06:41 AM
b18c1wes
Oct 6, 2004 02:11 AM
soulrider4ever
Feb 25, 2004 11:31 PM
