Running Nitrous, Cam selection Question.
Old Mar 13, 2006 | 11:13 PM
PinkMaggit's Avatar
Default Running Nitrous, Cam selection Question.
what would be a decent cam to run on nitrous? I want to be decent off the bottle and of course with a 100 shot make good use of the nitrous.
Original Plans
Blox Forced induction cams
Then..
Blox B's or S2s2 with intake retard
Im wondering about the new pro series? skunk 2 pros?
they have lots of duration is that bad for nitrous applications?
this will be my first time on the bottle....
thanks everyone.
Old Mar 13, 2006 | 11:14 PM
tegasaurus's Avatar
Default Re: Running Nitrous, Cam selection Question. (PinkMaggit)
you'll need less duration for nawz go with itr or s2s1 cams.
Old Mar 14, 2006 | 12:39 AM
crucian's Avatar
I would say, build your motor first to be as powerful as you can get the sucker, then spray the thing! Big cams!!!!
Old Mar 14, 2006 | 11:20 AM
PinkMaggit's Avatar
Default Re: Running Nitrous, Cam selection Question. (crucian)
The motor is being built right now.
forged pistons and rods.
Ported Head
Blox intake manifold
ericks T/B
Prototype Velocity Stack
Jun Valvetrain on Head
Working on getting a Rage, hytech or sparks header.
So once again what cam selection??
some said less duration for nitrous so im think s2s2 or blox B. which are junIII copies.
Im still thinking Pro series thought because I want to be fast off the bottle as well. I want 180HP+ off Plus a 100 shot of Nitrous.
Old Mar 14, 2006 | 11:59 AM
tegasaurus's Avatar
unless your running high compression, these cams your mentioning wont gain more than 10hp... same as a smaller cam in the long run. thats where i was going with the s2s1 idea. Or even get a set of buddy club IIIs. if you get a set of s2p2s or something equivalent, you'll need much higher compression than what you should run nitrous with (unless its on c16 and very very conservatively tuned). granted nitrous loves comression, there's that threshold you may cross over.
ps, what bore size will you be running?
Old Mar 14, 2006 | 03:27 PM
PinkMaggit's Avatar
Default Re: Running Nitrous, Cam selection Question. (tegasaurus)
they bored the stock block .20 over.
B18B
Compression is between 10.9 and 11.3
I wont be sure until the head is checked out for surfacing etc.
when i will use nitrous i will be on race gas or at least 100 octane (76)
so no on the pro series?
Turbo cams or s2s2s?
Old Mar 15, 2006 | 06:42 AM
PinkMaggit's Avatar
...ttt
Old Mar 16, 2006 | 03:31 PM
PinkMaggit's Avatar
ttt
Old Mar 18, 2006 | 08:34 PM
PinkMaggit's Avatar
Old Mar 18, 2006 | 11:20 PM
SiR831's Avatar
i run skunk stage 1's but i'm running a 10:1 comp and a 80 shot direct port.
Old Mar 19, 2006 | 08:49 AM
Phase Change Racing's Avatar
For the most part, cam selection plays almost no role in how your nitrous system is going to function.. in the Honda world. Unless you run adjustable cam gears and dial in a ton of overlap for some odd reason, you won't ever notice a difference.
I'll tell you what I tell everyone else on this subject, buy the cams that you want for best NA/Street performance and then throw the nitrous on top. One last thing, nitrous engiens DO NOT need less duration, if anything they prefer more.
Old Mar 19, 2006 | 05:59 PM
crucian's Avatar
Default Re: Running Nitrous, Cam selection Question. (Phase Change Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">For the most part, cam selection plays almost no role in how your nitrous system is going to function.. in the Honda world. Unless you run adjustable cam gears and dial in a ton of overlap for some odd reason, you won't ever notice a difference.
I'll tell you what I tell everyone else on this subject, buy the cams that you want for best NA/Street performance and then throw the nitrous on top. One last thing, nitrous engiens DO NOT need less duration, if anything they prefer more.</TD></TR></TABLE>That's what I was trying to tell him in my first reply! BIG CAMS!!! Make your engine powerful in N\A form, then spray the thing!
Old Mar 19, 2006 | 07:17 PM
PinkMaggit's Avatar
so pro2's would be Pimp to run on this engine? would be overcammed since its not that high of a compression ratio?
Old Mar 20, 2006 | 04:23 AM
crucian's Avatar
Well I would think big cams will be able to move the extra air and fuel in and out of the engine. Personally I won't worry about the compression ratio thing when it came to choosing the cam. Because the comprssion ratio you wil be running wont matter when you spray. You will want your cams to move all that extra stuff in and out. So what Im trying to say is, if you choose a, for example, B16 cam because it runs better on a paticular N\A motor, but when you spray, it cant move anything extra. Now you put some wilder cams that only give you 10hp in N\A form, but when you spray that sucker, you will feel a world of difference because that cam can move the extra gases... Hope you understand what Im trying to say.
Squirtin EGsr
Jan 17, 2006 06:25 AM
Icey112
Jun 26, 2005 04:47 PM
Pharcyde
Nov 6, 2002 08:04 PM
cjames235
Sep 20, 2002 07:47 AM
