RC 440 injector seals?
Old Mar 15, 2006 | 05:37 PM
jtracing919's Avatar
Default RC 440 injector seals?
do RC injectors use different seals than stock injectors? I am trying to put them in my gsr and the body seems to be a little bigger so I cant get them into the intake manifold
Old Mar 15, 2006 | 05:51 PM
beerbongskickass's Avatar
Default Re: RC 440 injector seals? (jtracing919)
I always thought they were drop in, but if they don't fit try a little WD40 or just grind them out a little bit. I had to grind out my o-rings to get my DSM 450's in.
Old Mar 15, 2006 | 07:21 PM
Integra21's Avatar
Default Re: RC 440 injector seals? (beerbongskickass)
mine were drop in
Old Mar 22, 2006 | 01:06 PM
chrisgottigsr's Avatar
try these
http://www.nopionline.com/nopi...01999
Old Mar 22, 2006 | 09:26 PM
Default Re: RC 440 injector seals? (chrisgottigsr)
are those the orings for the fuel rail end or the seals in the manifold. I am looking for the ones on the manifold end. I bored out the stock ones with a dremel for now, but I'd rather have the corret ones if i can get them.
Old Mar 23, 2006 | 04:50 AM
DannyDeuce's Avatar
I had the same problem.
All i did was get the rubber o-rings and sand them down to the stock size o-rings.
I just fit the RC injector rubber rings over a pencil and sanded away (alot easier that way).
Worked like a charm.
DAN
Turbo_Mike
10
Apr 12, 2009 08:18 AM
Unjockable
Mar 26, 2005 02:50 PM
Blackack26
Feb 20, 2004 10:59 AM
Farnsrocket
Dec 1, 2001 06:04 AM
