newb questions
Old Mar 17, 2006 | 11:32 AM
newcharacter23's Avatar
Default newb questions
hello honda tech, im new here.
i am currently boosting my b16a crx. it will be converted to obd1, and using hondata. i have rc 550cc injectors and i know i need the resistor pack. the pack is already wired in (since its not converted obd1 yet) so will these injectores be plug and play? 550's are peak and hold meanin i need the resistor pack correct?
Old Mar 17, 2006 | 12:20 PM
B18 CYA's Avatar
yes you need a resistor pack. the obd1 injector clips should fit but just remember, if you install the 550 cc injectors, you will immediately have to tune for it as the stock ecu won't make your car run with it.
beansandrice
33
Sep 8, 2009 04:18 PM
CRX44
Aug 31, 2009 11:13 PM
cor4ey
Nov 4, 2007 05:06 PM
teg92
Dec 13, 2002 11:08 AM
