ESTIMATE HP Output w/Ls vtec w/9.0 pistons h-eagle rods t3/t4 turbo @15 psi boost 3"exhaust cam gear
Pls can somebody with experience give an educated estimate at my power potential either at the wheels or crank.....
Thanks,,
Anxiously waiting to drop the motor in my car!!!
Thanks,,
Re: ESTIMATE HP Output w/Ls vtec w/9.0 pistons h-eagle rods t3/t4 turbo @15 psi boost 3"exhaust cam
Some more info on motor
LS bottom end
sir head
srp8.9:1 piston
eagle h beam rods
t3/t4 turbo @ 15 psi
900CC INJECTORS W/STR FUEL RAIL
FPR
255 WALBORO FUEL PUMP
skunk 2 manifold
3" exhaust
CAM GEARS
PULLEYS
GSR TRANNY W/OBX LSD
STAGE 5 CLUTCHMASTERS CLUTCH
?? CANT REMEMBER ANY THING MORE???
LS bottom end
sir head
srp8.9:1 piston
eagle h beam rods
FPR
skunk 2 manifold
3" exhaust
CAM GEARS
PULLEYS
your going to have to be a little more specific on the turbocharger. t3/t4's can make anywhere from 300-700
sounds like a 9,000,000,000,000,000 hp set up to me
seriously though...take it to a dyno if you want to know how much power it is going to make
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid93SIvic »</TD></TR><TR><TD CLASS="quote">sounds like a 9,000,000,000,000,000 hp set up to me </TD></TR></TABLE> I dynoed my old school Saturn 5 and it made just shy of that number
Depending what turbo I would say between 350-400 hp with a good tuner.
