just done a compression test. need help
Old Mar 18, 2006 | 04:14 PM
vi3t00si's Avatar
Default just done a compression test. need help
1st cylinder 140
2nd cylinder 55
3rd cylinder 130
4th cylinder 140
i boosted my 00 si yesterday and it started smoking at 5lbs of boost. im thinking its either the rings or the head gasket. its not over heating and it running the same. what are some of your opinions? i going to buy parts on monday.
Old Mar 18, 2006 | 04:21 PM
Tad's Avatar
Tad
yep, there is a definite problem with your engine then. You could have burnt a hole in ur piston, fried ur rings, maybe even valve seats, or if ur lucky it's just a headgasket.
What are you using for tuning, fuel/ignition ??
Basically, imo theres no need to worry about testing any further, you're going to have to pull the head regaurdless, so just pull ur head and find out whats going on in there.
Old Mar 18, 2006 | 04:36 PM
si0385.'s Avatar
Default Re: (Tad)
if its still running the same like no missfire or skip or anything i would do that compression test again...
if its still 55psi do just like tad said and take the head off
Old Mar 18, 2006 | 04:37 PM
96 GSR-T's Avatar
Default Re: just done a compression test. need help (vi3t00si)
That about sums it up, get your tools out, those otehr 3 cylinders are low in my opinion too but the one is just bombed out
Old Mar 18, 2006 | 04:38 PM
si0385.'s Avatar
thats not on stock internals is it?
if thats stock internals it should be higher than that
Old Mar 18, 2006 | 04:45 PM
komat's Avatar
Default Re: (si0385.)
my guess is the ringlands
Old Mar 18, 2006 | 06:10 PM
Tad's Avatar
Tad
fyi
u dont wana drive on an engine like this
u'll tear up ur cyl walls if it is rings.
then a rebuild will require a rebore, not just hone
Old Mar 18, 2006 | 06:25 PM
EK_GSR's Avatar
Default Re: (Tad)
anyone recommend a leak down test ?? compression tests are good, but leak down gives you the real 4-1-1 on whats wrong.
i had a similar problem a while ago, and it was due to a valve not sitting because the tune was too rich, so i had the head taken off, and re-cut the seat, and got another valve, and bam everythign was fine again. i just got it tuned by mase, and so now it is running 10x better that it was before.
so dont go tearing it down... but DO STOP DRIVING IT ! find the problem first you dont. want to make matters worse.
just my .02
Old Mar 20, 2006 | 08:15 AM
vi3t00si's Avatar
Default Re: (aallbbeerrtttttt)
what is a wet test? im gonna start taking the head off today.
Old Mar 20, 2006 | 08:17 AM
StolenTeg's Avatar
Default Re: (vi3t00si)
pour soem oil into the spark plug hoe and redo the compression test
Old Mar 20, 2006 | 08:46 AM
nonvtecD's Avatar
What fuel management were you using?
Old Mar 20, 2006 | 08:57 AM
rmcdaniels's Avatar
Default Re: (EK_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_GSR &raquo;</TD></TR><TR><TD CLASS="quote">anyone recommend a leak down test ??</TD></TR></TABLE>
^^^^^^^^^^^^^^^What he said^^^^^^^^^^^^^^^^
Do the leakdown test, it will show you what your problem is.
Old Mar 20, 2006 | 09:37 AM
Naterror's Avatar
wet compression test will tell you if it's you rings or not. Though with the numbers being that low, it's not just rings. A leakdown test will let you know if it's valves or headgasket.
I'd do both, but you diffenetly have something wrong that the heads going to have to come off to fix.
Old Mar 20, 2006 | 03:42 PM
vi3t00si's Avatar
Default Re: (nonvtecD)
im using an fmu.
Old Mar 20, 2006 | 03:43 PM
Tad's Avatar
Tad
get the head off yet?
Old Mar 20, 2006 | 03:44 PM
vi3t00si's Avatar
when i do the compression test. what numbers are considered good?
Old Mar 20, 2006 | 03:50 PM
I Have an STD's Avatar
wrenchin'
on a b16a?? anywhere from 185-210 across with very little variation from cyl to cyl. you need to get rif of that fmu. and if u happened to hook it up wrong and its not working right (i dont know how u could do this but its possible) then 5 psi could def smoke your motor. leak down test, then start buying parts
Old Mar 20, 2006 | 03:55 PM
D@nnY's Avatar
Default Re: (I Have an STD)
your ringlands are most likely dead from that fmu....youll probably need new pistons among other things
Old Mar 20, 2006 | 03:57 PM
Kowalski's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3t00si &raquo;</TD></TR><TR><TD CLASS="quote">im using an fmu.</TD></TR></TABLE>
i boosted my 00 si yesterday and it started smoking at 5lbs of boost.</TD></TR></TABLE>
Coincidence?
Old Mar 20, 2006 | 04:02 PM
ek_chris's Avatar
Default Re: (Tad)
yeah.. is the head off yet?? don't know what you are waiting for man
Old Mar 20, 2006 | 04:27 PM
drintegra's Avatar
What did you do when you did the compression test, exactly what you did? also when you boosted your motor, did you do a compression test before? WHat kit did you use, and what FMU? DId you have a Fuel pump? What Kind of smoke are you blowing white, black? Does the motor hesitate, stumble at idle and part throttle? Did you retard the timing when you installed the turbo? were you running a chipped ECU? See where I am going, there are alot of questions here that need to be answered. It is just weird a stock b16 blowing like that. Something happened?????
If the compression test was done correctly then you need to take off the head and just start over, new rings, have the head cleaned and valves seated. Might as well get pistons and rods since it is off and boost is addicting.
Good luck
Old Mar 21, 2006 | 04:18 PM
vi3t00si's Avatar
Default Re: just done a compression test. need help (drintegra)
i pulled the whole motor. im just gonna put my b18c1 in it for a while. were gonna take the head off the b16 sometime this week
Old Mar 21, 2006 | 06:57 PM
Tad's Avatar
Tad
yeah... you shoulda pulled that head man..
i really hope you dont plan to run that shitty fuel management on ur b18 as well
Old Mar 27, 2006 | 11:09 AM
vi3t00si's Avatar
Default Re: (Tad)
i put another b16 in and its compression is at 180 on all 4 so im hoping this will last a little longer.
Old Mar 27, 2006 | 02:38 PM
nonvtecD's Avatar
if you turbo this one get some real management
