help with my turbo installation!?
Old Mar 13, 2006 | 04:49 PM
lecy55's Avatar
Default QUESTION REGARDING MY TURBO!??
I just installed a TB0357 Saab Turbo w/ a/r .42 compressor, a/r .48 turbine, and .45 trim Manifold w/ external wastegate mount Tial Wastegate at 11.6psi.
My problem is that I seem not to be getting the full "potential" out of the turbo and I'm only getting about 4 Ibs. of boost out of it..... also there seems to be oil coming from somewhere around the turbo housing... anyone know what the problem is?
Modified by lecy55 at 6:07 PM 3/13/2006
Old Mar 13, 2006 | 05:21 PM
zcgod's Avatar
sounds like a bad seal
Old Mar 13, 2006 | 05:41 PM
lecy55's Avatar
Default Re: (zcgod)
bad seal in what?
Old Mar 13, 2006 | 05:54 PM
ccivic's Avatar
Default Re: (lecy55)
If you are running a big feed line (larger than -3AN) use a .065" restrictor (search). Also, make sure your drain line has no kinks, and comes down at a nice angle.
Check for loose clamps on your charge piping, check for any rips/tears/holes in your couplers.
Old Mar 13, 2006 | 06:36 PM
lecy55's Avatar
Default Re: (ccivic)
what would happen if I didn't have a .065" restrictor with a big feed line?
Old Mar 13, 2006 | 07:43 PM
Jay_Sensing's Avatar
Oil would come out everywhere lol.
Not really but over time it probably would. They can't drain fast enough and the oil is still being pushed into the cartridge so it has to go somewhere, it finds the weakest point which is the seals and pushes out into the downpipe and compressor housing. Makes for lower octane and bad spark plug life plus a **** load of smoke.
Old Mar 13, 2006 | 08:21 PM
lecy55's Avatar
Default Re: (Jay_Sensing)
yeah that might be my problem because i did have oil everywhere ( even some on the underside of the hood) but i dont really notice any smoke.... however my turbo manifold heats up extremely fast and start to smoke would this be a related problem?
Modified by lecy55 at 2:45 PM 3/14/2006
dturbo
Apr 5, 2005 03:44 PM
slo_crx
Oct 12, 2004 05:51 PM
alfee
Jul 30, 2004 02:42 PM
GReddy SI
Jul 27, 2004 12:51 PM
B18badboy
Apr 27, 2004 09:01 PM
