turbo tuning low idle HELP!!
i got these injectors used
i have a d16z6 with a 14b and dsm 450cc and vafc2
i cannot get my car beyond 700 rpm when idling
i have the % set at -38 across the board and changing it higher or lower doest affect my idle
the throttle postion is 98% 99%
someone please help
im not running a missing link or check valves, and when im in nuetral and press the gas there is no hesitation but when i drive and vacuum tries to go past 0 it wont it will bog/cut out
Modified by exotik4doorcivic at 7:38 PM 3/18/2006
someone please help
Re: turbo tuning low idle HELP!! (iBrandon)
there is no idle screw the one inder the throttle body is gone but before i installed the injectors it ran fine
Re: turbo tuning low idle HELP!! (exotik4doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic »</TD></TR><TR><TD CLASS="quote">there is no idle screw the one inder the throttle body is gone but before i installed the injectors it ran fine</TD></TR></TABLE>
huh?
huh?
??huh
??huh
the in is 98% and out is set at 99%
why are you trying to set the idle with the vafc?
Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife »</TD></TR><TR><TD CLASS="quote">any check engine lights?</TD></TR></TABLE>
theres no check engine light for doofus operator
Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
theres no check engine light for doofus operator</TD></TR></TABLE>
haha
haha
Re: (D@nnY)
Some check engine lights would never shut off..
Re: (VTC_CiViC)
all im trying to say is before i installed the injectors it idled fine, i set the correction -40% across the board on high cam and low cam
06 in 06 out
throttle position is 98% 99%
im not trying to raise or lower my idle with the vafc im trying to get my a/f correct to ensure im not dumping too much fuel into my engine or not enough
i just dont understand why before my idle was perfect and now it idles around 600-700
06 in 06 out
Re: (exotik4doorcivic)
the screw i was talking about was the screw underneath the throttle body under the butterfly handle if you screw it in or out it will adjust your idle
Re: (D@nnY)
i found the problem
one of the wires on the tps sensor was out so it wasnt reading throttle % therefore
dumping way too much fuel
i just took it for a drive and its insane im only running 6 lbs of boost too!
d16z6
14b turbo
dsm 450cc's
apexi vafc2
spearco intercooler 2 1/2 inch charge pipes
monza bov
msd ignition blaster 2
act stage 2 clutch, 12lb flywheel
b and m shifter
thermal r&d exhaust
i need to get a high flow cat
d16z6
14b turbo
dsm 450cc's
apexi vafc2
monza bov
b and m shifter
thermal r&d exhaust
