Boost guage bounces
Old Mar 17, 2006 | 07:11 AM
StolenTeg's Avatar
Default Boost guage bounces
I have a Faze 30 inhg and 30 psi boost gauge, it read pretty acurate but the problem is that when it reach full boost it would bouce back and forth like crazy.
Let say im running 8 psi, it would bounce between 7-9 nonstop, is this a problem with the gauge or something is up with the vacuum source it seeing?
Old Mar 17, 2006 | 07:35 AM
skratchnsnift's Avatar
i would check the vacuum lines.
Old Mar 17, 2006 | 07:46 AM
Srr's Avatar
Srr
could b da gauge too.... spring or something mite b weak...
Old Mar 17, 2006 | 07:56 AM
StolenTeg's Avatar
Default Re: (Srr)
There shouldnt be any vaccum leak because i idle at 21 inhg
Old Mar 17, 2006 | 10:27 AM
f1 vtec's Avatar
Default Re: (StolenTeg)
i say you should bounce the gauge of the floor a few times, it usually works
Old Mar 17, 2006 | 10:41 AM
adseguy's Avatar
Default Re: (f1 vtec)
Are you using a boost controller? Is this a new problem? Can you check your map sensor to make sure the boost is flucuating? What type of manifold and wastegate are you using?
Need as much relevant info you can provide.....your just stating a problem.
CivicDude2k4
Jul 31, 2006 08:18 AM
Sprayin_civic
Aug 26, 2004 10:35 AM
turbonitrousgsr
Oct 6, 2003 06:54 AM
cajnatc
Jun 13, 2003 04:18 AM
quikrpm'z
May 29, 2002 10:13 PM
