Problem torqing down headstuds/messed up thread maybe? Help me plz.
Old Mar 14, 2006 | 05:28 AM
90teg's Avatar
Default Problem torqing down headstuds/messed up thread maybe? Help me plz.
This is what happened, I installed my turbo kit about 3weeks ago. I ran the car about 4psi on the boost gage. I was running off the wastegate spring no boost controller. Ran fine all nite. Next morning I decided to drive to Napa for some oil and the car had NO power at all. As if it wanted to stall, I drove the car back home(limping all the way) and park the car and saw while smoke. At first I thought it was my turbo, but when I toke my exhaust manifold off port #4 was covered in oil. So I bought a new head gasket thinking it was that, when I was loosening the headstuds 1-3 loosened fine but when I got to stud #4 it did not want to move. With a LOT of strenght it finially broke loose but entire time I was loosening it make a kinda like a squeeling sound. All the other 9 studs came out fine except that one. I decided to put them all back in and torque them back down to see if the same would happened again, All 9studs torqed down fine except #4 it started screwing down fine until it started getting tight then started squeeling and it did not feel like it was torqed to 61ft lbs. This is on a gsr motor, I got the head milled because it was warped. Toke off .005, is the thread messed up or the bolts?
Old Mar 14, 2006 | 05:33 AM
Turbo-charged's Avatar
Default Re: Problem torqing down headstuds/messed up thread maybe? Help me plz. (90teg)
probably skanky threads....timesert makes a repair kit for it....the size you need is M11x1.5
sounds to me like you need new pistons, not a headgasket.
Old Mar 14, 2006 | 07:57 AM
90teg's Avatar
Why do you think I need new pistons?
Old Mar 14, 2006 | 10:14 AM
90teg's Avatar
Anyone else?
Old Mar 14, 2006 | 10:43 AM
Default Re: (90teg)
the way you described your problems does not sound like headgasket, especially at 4psi. if you were talking 44psi then i might think headgasket, but it sounds to me like you smoked up a piston. also if you took off your exhaust manifold and the turbo was filled with water, not oil, then i would suspect head gasket, cracked sleeve, or dropped sleeve. its very rare for b series headgaskets to randomly blow, if the gasket does blow, its usually the result of something else.
have you taken the head off yet?
Old Mar 14, 2006 | 12:57 PM
s2kdre's Avatar
Default Re: (Turbo-charged)
u never reuse the stock headstuds they stretch
Old Mar 14, 2006 | 02:56 PM
90teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">the way you described your problems does not sound like headgasket, especially at 4psi. if you were talking 44psi then i might think headgasket, but it sounds to me like you smoked up a piston. also if you took off your exhaust manifold and the turbo was filled with water, not oil, then i would suspect head gasket, cracked sleeve, or dropped sleeve. its very rare for b series headgaskets to randomly blow, if the gasket does blow, its usually the result of something else.
have you taken the head off yet?</TD></TR></TABLE>
I've taken the head off 3 times on saturday. The turbo, wastegate, port #4 on the exhaust had oil and water. I used arp headstuds today with the new headgasket and no more smoking. The motor has 170,000 so a bad headgasket was a very good possibly. Why wouldn't you reuse stock head studs? I've done it before with no problems except this time.
Old Mar 14, 2006 | 03:17 PM
blackeg's Avatar
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">
I've taken the head off 3 times on saturday. The turbo, wastegate, port #4 on the exhaust had oil and water. I used arp headstuds today with the new headgasket and no more smoking. The motor has 170,000 so a bad headgasket was a very good possibly. Why wouldn't you reuse stock head studs? I've done it before with no problems except this time.</TD></TR></TABLE>
they stretch. maybe under n/a driving conditions you can get away with it, but under boost, the head can lift/blow the gasket
ufakeit
14
Sep 26, 2009 05:51 PM
Ntense90crxsi
Aug 18, 2009 08:07 PM
adamez
Nov 2, 2006 06:26 PM
t3t4delsol
Oct 11, 2006 12:23 PM
BDaTurboTeg
Oct 1, 2006 07:43 AM
