spark plug question for ls turbo guys
Old May 12, 2008 | 04:25 PM
blackccoupe's Avatar
Default spark plug question for ls turbo guys
hey guys i'm running the bkr7es-11 in my car right now sometimes idle is a lil rough, i read an artical that was saying the v power plugs are better for turbo cause of better spark and idle smoother i would like and any input from you guys like the plugs ur running and what ones u had probelms with thanks
Old May 12, 2008 | 05:18 PM
dscivicdx's Avatar
Default Re: spark plug question for ls turbo guys (blackccoupe)
did you regap them or are you running them right out of the box?
Old May 12, 2008 | 05:33 PM
blackeg's Avatar
Default Re: spark plug question for ls turbo guys (dscivicdx)
re-gap them. try using .028" to start. it will also help while in boost
Old May 12, 2008 | 05:39 PM
dscivicdx's Avatar
Default Re: spark plug question for ls turbo guys (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">re-gap them. try using .028" to start. it will also help while in boost</TD></TR></TABLE>
+1
Old May 12, 2008 | 06:27 PM
.030 gapped
Old May 14, 2008 | 01:42 PM
inspyral's Avatar
I'm running BKR7-E/BKR7E-11 gapped at .030". My idle is fine. I've also run the Race non-resistor plugs with no problems.
Old May 14, 2008 | 04:56 PM
Default Re: (inspyral)
i threw in a new o2 sensor and soemplugs i'll see if that helps
hondamn1320
Mar 12, 2008 09:33 AM
thestorysritehur
Mar 11, 2008 08:34 PM
dunkd
Jul 15, 2006 09:21 AM
silverb18
Mar 24, 2005 10:26 AM
RobbieG35
Dec 16, 2004 05:08 PM
