Need turbo help
Old May 14, 2008 | 11:05 PM
Sofakingtyte's Avatar
Default Need turbo help
OK guys, im in the market for a new turbo and need your help, here is my info so you guys can help me out:
MOTOR SETUP
I have a fully built and GE sleeved 84.5mm low compression CP pistons, eagle rods, everything balanced, GSR motor with a fully built head with oversized ferrea valves along with a ferrea valvetrain and an AEBS intake manifold with a 68mm throttle body.
Turbo setup
SLS T3 topmount manifold 3in downpipe, 38mm wastegate, RC1000cc injectors, AEM EMS, Medium sized intercooler. walboro 255 fuel pump
I believe thats all the important stuff, so here is what i would like to accomplish. I want to have between 400-500hp on pump gas, and want to make comfortably make between 600-700hp on race gas. I dont want a boost transition that feels like a light switch, as i have read that comes from a t3/t67. and i dont want major turbo lag either.
So what turbo should i use, I have really considered a gt3582r but that turbo maxs out around 650hp. Is the gt35r the best turbo i can get that will fit my T3 flange? Is there any BW, precision, or turbonetics turbos i can get that will meet my goals? thanks a lot H-t and sorry for the essay
Old May 14, 2008 | 11:23 PM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: Need turbo help (Sofakingtyte)
for those goals, yes the 35R will suit your needs nicely. I'm looking for the exact numbers and have already bought the turbo... Wish I had it done so i could tell you results but not yet!! good luck!
Old May 14, 2008 | 11:24 PM
GT35R_EF's Avatar
Default Re: Need turbo help (GT35R_EF)
the only thing I would change here is the 38mm wastegate to a 44mm. Might see some creeping issues there.
Old May 15, 2008 | 12:22 AM
Is there anything i can do to help that 38mm wastegate problem?
Old May 15, 2008 | 04:45 AM
chimmike's Avatar
Default Re: (Sofakingtyte)
IIRC, if you run high boost levels, the smaller wastegates are good.
Old May 15, 2008 | 05:26 AM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sofakingtyte &raquo;</TD></TR><TR><TD CLASS="quote">OK guys, im in the market for a new turbo and need your help, here is my info so you guys can help me out:
MOTOR SETUP
Turbo setup
you are limited with the t3 flange so there arent many choices to make 700whp. a gt3567r could possibly work, or a t3/t67 with a p trim exhaust heel aka gt37r aka t3/t67 H.O.
no need to worry about anything because your fuel system cant support your power goals anyway.
yannibeee
Jun 16, 2016 05:20 AM
Tmnjlb123
Sep 16, 2014 03:34 AM
DreXeL_UK
Apr 11, 2008 11:40 PM
itsthatguy
Nov 19, 2004 09:01 PM
Joel_MN
Aug 18, 2003 06:14 AM
