gt35r coolant lines
Old May 4, 2008 | 10:34 AM
dartonh22's Avatar
Default gt35r coolant lines
how do you guys run your coolant lines for you ball bearing turbos, mine is coming out of the side of the head (heater hose) into the turbo out the turbo and into the other end of the heater hose going into the heater core
or vise versa depending on which way the coolant flows, that another question i have which way does the cooalnt flow through the heater core.
i am asking this beacause i think my turbo is heating up my coolant flowing into my head causing the car to overheat.
Modified by dartonh22 at 12:34 PM 5/4/2008
Old May 4, 2008 | 11:40 AM
.adam.'s Avatar
theres already a multipage thread on here with numerous different setups, search
Old May 4, 2008 | 01:01 PM
dartonh22's Avatar
Default Re: (.adam.)
i have searched, and none of them say which way the coolant runs as far as the heater hoses go, and does coolant flow through the hoses if the heat is off, by the way the car is a prelude if it matters.
Modified by dartonh22 at 2:07 PM 5/4/2008
Old May 4, 2008 | 01:08 PM
SD_Lurker's Avatar
HT White Ops
Default Re: gt35r coolant lines (dartonh22)
https://honda-tech.com/zerothread/1920697
Old May 4, 2008 | 01:33 PM
dartonh22's Avatar
Default Re: gt35r coolant lines (SD_Lurker)
thanks for the link, i looked at that before, not very many for h22 setups, and my hoses are alot bigger than that, they're the same size as the heater hoses, h series doesnt have that spout coming of the housing on the head.
but do you guys think the way i have it, is a possible cause of overheating, how else could i run it so the coolant doesnt return into the motor
Old May 4, 2008 | 08:18 PM
IN VTEC's Avatar
https://honda-tech.com/zerothread?id=2289412
Old May 5, 2008 | 01:18 PM
dartonh22's Avatar
Default Re: gt35r coolant lines (IN VTEC)
yeah, those look good, is the rear hetera hose on the back of the block for the exit of coolant from the block., i really dont want to recirculate my turbo line back into the motor, and would using a T restrict flow at all.
IntegraTypeR
Aug 17, 2007 07:20 AM
RTW DC2R
Jun 3, 2006 07:20 PM
