Budget turbo build, map sensor problem
Old May 4, 2008 | 01:39 PM
shaggyeg6si's Avatar
Default Budget turbo build, map sensor problem
Okay, so we all know of this problem. What is there that I can use to make the map sensor see the proper amount of pressure? I have seen missing links, but those are mounted on the throttle body, and a map defensor, but thats just a one way valve. Anyone got any ideas?
Old May 4, 2008 | 03:38 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Budget turbo build, map sensor problem (shaggyeg6si)
Yes, get a chipped ECU that will actually use the MAP sensor to set the fuel and timing. If you want a hack, then go to a pet store and buy aquarium check valves, that will keep the MAP from seeing boost. It's a hack, it is not a solution.
Old May 6, 2008 | 12:58 PM
Default Re: Budget turbo build, map sensor problem (Maxbore.com)
I did that, but it drove like it ran into a brick wall because the only signal that the map sensor will see is the maximum vacuum pulled.
Old May 7, 2008 | 09:44 AM
No Big Whoop
Sorry I am not following. What do you mean max vacuum pulled?
It seems you have a bad MAP sensor.
Old May 10, 2008 | 05:58 PM
Well the check valve will allow air one way, and so it will keep letting air in one way, so whatever the maximum vacuum that the check valve sees, it will hold that vacuum.
Old May 10, 2008 | 06:36 PM
joppe's Avatar
U need to instal 3-5 valves in that hose witch goes to map sensor, valves are installed so that it will bleed boost before it hits map sensor. Using missing link is very stupid and ur motor is running super lean on boost. MAP sensor is now saving ur motor, when u hack that ur motor can ran lean and detonate and results are blown pistons, head gasket, rods, its good way to blow ur engine.
This is wrong place to save on budget turbo, so get ur ecu tuned and chipped. Chipping n tuning stock ecu isnt that expensive, go and see http://www.xenocron.com and spent time learning tuning and chipping etc before blown ur motor with wrong tune.
Old May 12, 2008 | 11:32 AM
Default Re: Budget turbo build, map sensor problem (joppe)
I'm looking into tuning it myself, so burning my own chips is high on the list. I am recently from the obd1 civics so all of this is a little new to me.
Old May 13, 2008 | 03:34 AM
joppe's Avatar
Get ostrich emulator. U dont have to burn chip, and u can tune while driving.
Old May 13, 2008 | 08:14 AM
Will look into that. Thanks for the info. But what do you mean by valves to bleed? Like what kind of valves?
Old May 13, 2008 | 07:28 PM
joppe's Avatar
When u run crome or something to tune u dont have to use any check valves.
Old May 14, 2008 | 02:24 AM
No Big Whoop
I don't get what you are doing, but this is what you need to do to prevent the MAP from seeing boost.
Go to a pet store and buy 3 aquarium check valves. Suck on each one to make sure which way they flow. On the hose going to the map sensor, place the 3 valves in a row in a way that you can suck away from the MAP sensor but cannot blow into it.
That's it.
Get a chipped ECU
Old May 15, 2008 | 07:48 AM
well I tried the check valve. although I only had one installed. it really seemed to run worse because of it. but the kit has been taken off. I have been having some problems with the motor and so I have decided to swap in a ls motor. maybe turbo it then. I will keep you guys in the know though.
16STCRX
Oct 15, 2003 08:57 PM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
