car is not starting
Old May 14, 2008 | 07:35 PM
JDM_95_LS's Avatar
Default car is not starting
alright well i just bought a 00 b18b motor, i'm running a 57 trim garrett turbo with 440cc precision injectors, crome chipped ecu, and i just changed the headgasket. now the motor doesn't start. it's getting spark and fuel, i can't figure out what's wrong so i'm asking everyone on here to help me out.
Old May 14, 2008 | 07:44 PM
b18b1turbo's Avatar
Default Re: car is not starting (JDM_95_LS)
try your air temp and your map sensors.might be switch around
Old May 14, 2008 | 07:52 PM
JDM_95_LS's Avatar
Default Re: car is not starting (b18b1turbo)
could that be a problem?
Old May 14, 2008 | 08:09 PM
b18b1turbo's Avatar
that might be it
Old May 14, 2008 | 08:24 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1turbo &raquo;</TD></TR><TR><TD CLASS="quote">try your air temp and your map sensors.might be switch around</TD></TR></TABLE>
Map is a 3 wire, air temp is a 2 wire, they aren't interchangeable.
Proper fuel map scaling is important for the bigger injectors, as well as timing. Is the tuner who is/has doing the tuning having trouble, or is this just you 'hoping' it will start with god knows what on the 'chipped ecu'?
Old May 14, 2008 | 08:38 PM
b18b1turbo's Avatar
Default Re: car is not starting (HamiltonRex)
opps my bad meant to say tps and map.
Old May 15, 2008 | 12:45 PM
JDM_95_LS's Avatar
nope it's put on right. i still need help
Old May 15, 2008 | 04:47 PM
JDM_95_LS's Avatar
bump!
Old May 16, 2008 | 03:11 PM
JDM_95_LS's Avatar
bump! need help asap
Old May 16, 2008 | 05:19 PM
90blackcrx's Avatar
Timing off ? Cam timing ?
Old May 17, 2008 | 07:45 PM
JDM_95_LS's Avatar
Default Re: car is not starting (90blackcrx)
no timing is right
Old May 18, 2008 | 10:18 AM
90blackcrx's Avatar
Do you have fuel ? Do you have spark ? Do you have compression ? Only things you need to start an engine.
Old May 18, 2008 | 11:13 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Do you have fuel ? Do you have spark ? Do you have compression ? Only things you need to start an engine. </TD></TR></TABLE>
Man, if that's not a gross generalization, than I'm Bill Clinton.
OP.
What do you mean by the car is "not starting" besides the obvious.
Does it not crank what so ever. Does it crank and not catch at all. Does it crank, catch, and then stumble?
Check your grounds. Triple check all of your plugs. Etc etc etc.
Old May 18, 2008 | 11:15 AM
90blackcrx's Avatar
Default Re: car is not starting (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">
OP.
Check your grounds. Triple check all of your plugs. Etc etc etc.</TD></TR></TABLE>
Its getting fuel and spark so it has to be cranking, if its getting fuel and spark, then it must not have compression, or else it would kick over. Unless he has his spark plug order all wrong, injectors in the wrong order. If that was the case, he shouldn't be changing head gaskets.
And if your Bill Clinton , I'm gonna send you an IM to chat about somethings.
Modified by 90blackcrx at 12:23 PM 5/18/2008
Old May 18, 2008 | 11:32 AM
Schister66's Avatar
Man U FTW
I'm in the same boat right now...my built LS/VTEC wont start
Good luck
FSA
Honda Civic (2006 - 2015)
Jul 7, 2010 06:24 PM
A13sechatch
Engine Management and Tuning
Jul 26, 2009 02:48 PM
HydroHybrid
Jun 30, 2008 06:10 AM
Akalima
Jun 2, 2008 04:03 PM
abmerop18
Jan 19, 2005 07:08 AM
