biggest turbo on stock sleeve d16?
fully built d16z6 turbo in the making, and what would be the biggest turbo i can use with the max psi on the stock sleeves?
i see a lot of people making 400 n up on stock sleeves
Re: (joe111599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe111599 »</TD></TR><TR><TD CLASS="quote">t3/t4 57 trim .63 a/r...dont need ANY bigger. IMO</TD></TR></TABLE>
Why not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef »</TD></TR><TR><TD CLASS="quote">fully built d16z6 turbo in the making, and what would be the biggest turbo i can use with the max psi on the stock sleeves?
i see a lot of people making 400 n up on stock sleeves </TD></TR></TABLE>
Im confused on the "biggest turbo w/ the max psi" part? It all depends on your WHP goals. If you're goal is between 300-400whp, there are a number of turbos you can go w/ at fairly low PSI. Im running a Gt3076r on my built D16z6 at 12psi and should be seeing close to 300whp
Why not?
98-DC4
03-10-2008 05:37 PM
*Boostwerks*
01-26-2007 07:40 PM
