BW s366 or Gt4088r
Old May 11, 2008 | 04:40 PM
KillAHonDa's Avatar
Default BW s366 or Gt4088r
hey all, i tried to search this but for some reason it says the "search" is temp unavailable... im in the market for a turbo and im undecided on wich one to go with .. either Bw s366 or gt4088r .. my build is a ls/vtec 82mm my power goal is High 600's to low 700's - lmk what yall think of either turbo's
thanks
Old May 11, 2008 | 05:31 PM
flaco0018's Avatar
bw s366 my car made 470whp at 16psi on a 2.0l b18c on stock head,+1 to bw
Old May 11, 2008 | 05:46 PM
Turbo-charged's Avatar
Default Re: (flaco0018)
S366
the 4088 has an awesome power band but runs out of breath too early IMO
Old May 12, 2008 | 07:27 AM
KillAHonDa's Avatar
Default Re: (Turbo-charged)
thanks guys.... anyone else got any opinions? /advise/feedback/KNOWLEDGE!! lmk
Old May 12, 2008 | 08:40 AM
ghostofnyc's Avatar
BW
Old May 12, 2008 | 09:33 AM
EF9JiM's Avatar
i say you go with the gt40.
Old May 12, 2008 | 09:54 AM
TheShodan's Avatar
Moderator
Default Re: BW s366 or Gt4088r (KillAHonDa)
Give us a bit more information about your budget, and your setup to use with a T4 return flange. Both can work, but if you don't want to worry about water lines, or some other issues you tend to worry about, that would help in your decision.
Old May 12, 2008 | 10:33 AM
KillAHonDa's Avatar
Default Re: BW s366 or Gt4088r (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Give us a bit more information about your budget, and your setup to use with a T4 return flange. Both can work, but if you don't want to worry about water lines, or some other issues you tend to worry about, that would help in your decision.</TD></TR></TABLE>
well i would obviously want to keep cost down as much as possible, as far as my setup gose right now this is what i have. B18A Block 82mm,darton Sleeved,mahle Pistons,scat rods 9.5:1 - Gsr Head Supertech valves,springs,and ret. stock GSR cams (might ugrade to skunk2 pro2's) gsr Tranny CC twindisk,obx LSD - Fullrace RamHorn Mani its a t3 but im going to cut the flange and weld a t4, 44mm WG and Presicion 750 IC
Old May 12, 2008 | 11:20 AM
extralargenog's Avatar
GT4094r
Old May 12, 2008 | 11:36 AM
BoostedJeff's Avatar
Default Re: BW s366 or Gt4088r (extralargenog)
S366, Bullseye Power
Old May 12, 2008 | 01:13 PM
Ef Si's Avatar
Default Re: BW s366 or Gt4088r (BoostedJeff)
They both will make roughly the same power (675hp-725hp) but the gt4088 will have a nicer powerband and better transient spool.
Old May 12, 2008 | 01:33 PM
Default Re: BW s366 or Gt4088r (Ef Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef Si &raquo;</TD></TR><TR><TD CLASS="quote">They both will make roughly the same power (675hp-725hp) but the gt4088 will have a nicer powerband and better transient spool.</TD></TR></TABLE>
4088s seem to stop at about 675whp on an accurate dyno. I would say that the 366 is good for around 50whp more than than the 4088.
Not to mention Bullseye has the best customer service I have EVER dealt with, and I don't know about everyone else, but having damn near 24hr support is very important to me.
We have not had a problem with any bullseye units thus far, I don't plan on ever switching back.
Old May 12, 2008 | 03:10 PM
mrbsponge's Avatar
Ive had an s366 on my car for since sept 07, i love the heck out of it, power is retarded!
on my low boost setting which is 18psi the car made like 488. my high boost setting which is about 30 now netted me just a hair over 700 on C16 with me tuning it.
motor is an 84mm gsr with 9.5:1, skunk2 stage 1s, carbon intake manifold, full race topmount.
revving to about 10.5K car pulled past 9k. spool is as fast as my 35R any day of the week
i ran a traction limited 10.3 spinning 4 gears
Old May 12, 2008 | 06:19 PM
dome's Avatar
Default Re: (mrbsponge)
whats the s366 run
Old May 12, 2008 | 10:22 PM
mrbsponge's Avatar
Default Re: (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">whats the s366 run
bout 1500
Old May 13, 2008 | 04:36 AM
boosted hybrid's Avatar
The bushing gt4088 has larger wheels (both turbine and compressor...65mm inducer on compressor) than the bb gt4088r and is around 800.00. It makes about 50whp more than the bb gt4088r.
Old May 13, 2008 | 10:26 AM
EF9JiM's Avatar
i did some research on the bulls eye. that's the way to go.
Old May 13, 2008 | 12:02 PM
mrbsponge's Avatar
Default Re: (EF9JiM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9JiM &raquo;</TD></TR><TR><TD CLASS="quote">i did some research on the bulls eye. that's the way to go. </TD></TR></TABLE>
you better believe it!
Old May 13, 2008 | 12:13 PM
xsi-t's Avatar
Bullseye power all the way (BW)
Old May 13, 2008 | 12:16 PM
KillAHonDa's Avatar
Thanks for all the info guys! after all your inputs and research i am going with the BW s366 - placing my order on friday - woohoo!
Old May 14, 2008 | 04:50 AM
ghostofnyc's Avatar
good decision
Old May 14, 2008 | 05:25 AM
Urban_Indian's Avatar
HX52
Old May 14, 2008 | 06:43 AM
mrbsponge's Avatar
Default Re: (Urban_Indian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban_Indian &raquo;</TD></TR><TR><TD CLASS="quote">HX52</TD></TR></TABLE>
didnt see the hx52 on his list anywhere?
Old May 14, 2008 | 04:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">
Thats ok, guess if its not super JDM ballerness you dont approve eh.
its cheaper and will flow more and is another OPTION TO CONSIDER since I went through this https://honda-tech.com/zerothread/2274539
Either way go if the HX52 doesnt go with HT standards then I would recommend a BW 368 and a race cover.
My opinion is you should stfu
Modified by Urban_Indian at 5:47 PM 5/14/2008
Old May 14, 2008 | 05:12 PM
Justin Olson's Avatar
Default Re: (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">The bushing gt4088 has larger wheels (both turbine and compressor...65mm inducer on compressor) than the bb gt4088r and is around 800.00. It makes about 50whp more than the bb gt4088r.</TD></TR></TABLE>
Didn't know about this??? Do you have some dynocharts on your sight comparing the BB vs journal bearing?
Regards,
Justin
jiggacivic
Dec 29, 2010 09:13 AM
Blake8418
Jan 14, 2009 09:32 AM
corollagts33
Sep 18, 2005 10:49 AM
JdM_Eg_6
Feb 25, 2004 02:13 PM
94ls
Nov 12, 2003 01:01 PM
