another high HP build
Old May 4, 2008 | 04:05 AM
wabaki's Avatar
Default another high HP build
finally after months of planning things are finally coming together
new set up:
borg warner S372 .90ar turbo
twin tial 38mm w/g
PTE 750hp intercooler
tial 50mm bov
custom t4 topmount manifold
3.5 to 4 inch dp
engine:
b16b type r block
b20 crank
Crower pro rods
wiseco 83mm pistons
Darton MID sleeves
golden eagle head studs
ACL bearings
ARP main bolts
type r head ported
supertech valves
supertech springs and retainers
ITR 98spec cams
custom intake manifold
competition clutch stg.6 ironman clutch
engine management:
AEM 30-1000 ecu
aeromotive A-1000pro pump
aeromotive Fuel reg
lucas 1600cc injectors
FJO injector driver
s372 vs t3/t4
Old May 4, 2008 | 04:21 AM
tekturbo's Avatar
Thats wtf Im talking about good luck on the build. post those #s asap.
Old May 4, 2008 | 05:09 AM
Schister66's Avatar
Man U FTW
If you're planning on making real use of that S372, you're going to need a better clutch for starters. You're not going to get much out of that Comp Stage 6 before it basically melts. Twin disk or nothing at this point. Also, your ITR cams are going to hold you up. You need a set of Skunk2 Pro 1's or Mazworks cams or something...more aggressive than the ITRs anyway
Old May 4, 2008 | 07:32 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">If you're planning on making real use of that S372, you're going to need a better clutch for starters. You're not going to get much out of that Comp Stage 6 before it basically melts. Twin disk or nothing at this point. Also, your ITR cams are going to hold you up. You need a set of Skunk2 Pro 1's or Mazworks cams or something...more aggressive than the ITRs anyway</TD></TR></TABLE>
most of that makes sense, but ITR cams are proven to make big power, hell people have made over 700 on gsr cams, so i know that itr cams would be sufficient for his build
Old May 4, 2008 | 10:11 AM
Schister66's Avatar
Man U FTW
Oh, i'm not denying that it can be done, but depending on his power goals, a new set of cams might be in order. Its definitely not a must, but merely a suggestion
Old May 4, 2008 | 05:16 PM
trujdmek's Avatar
whats the rod length on the crowers im tring to do a very similar build. very few know the marvels of the ctr lol
Old May 4, 2008 | 05:31 PM
wabaki's Avatar
clutch is just to get the car running up. an exedy twin plate will go in the mix. as for the cams its what i have from my previous engine so it will go in for now but i will upgrade if i have to
CTR block has a 270mm deck height same as a b18c il be using standard lenght b18b rods with the 89mm crank
Old May 4, 2008 | 07:27 PM
wabaki's Avatar
has anybody run the crower 63411T-2 race cams?
turbolsvtecej1
Feb 21, 2012 05:39 PM
miata
Nov 13, 2007 02:09 PM
IntegraXSi
Dec 26, 2003 05:15 PM
