4" Intercooler Too big?
Old May 8, 2008 | 02:04 PM
RedneckRicer's Avatar
Default 4" Intercooler Too big?
friend has a Dual backdoor FMIC off a SRT 4 and it almost lines up perfectly for my setup but its 4" thick. wont that cause alot of pressure drop for me since 4" seems like a huge overkill. if anyone has experience with a 4" FMIC lemme know.
Setup is going on a 400-450 whp GSR built civic.
Old May 8, 2008 | 02:14 PM
chimmike's Avatar
Default Re: 4" Intercooler Too big? (RedneckRicer)
it's not so much the pressure drop as it is a 4" thick core, the thicker the core, the fractionally less effective the additional thickness is.
I think a 3" core is about as much as you'd need, 4" really goes too much, unless you're running like 700-800whp or more.
Old May 8, 2008 | 02:41 PM
Schister66's Avatar
Man U FTW
Although i dont know the rest of the dimensions of the intercooler, i would assume that this is going to be quite a bit larger than necessary. Most times a 4" core is used for higher HP setups (600-700+)
Old May 8, 2008 | 09:17 PM
core is 24x12x4
Old May 9, 2008 | 12:52 AM
joe111599's Avatar
I would use it if it were me. Wouldnt even think twice...especially if it lined up and everything...lol.
Old May 9, 2008 | 04:44 AM
chimmike's Avatar
Default Re: (joe111599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe111599 &raquo;</TD></TR><TR><TD CLASS="quote">I would use it if it were me. Wouldnt even think twice...especially if it lined up and everything...lol.</TD></TR></TABLE>
I wouldn't. Bigger is not always better with intercoolers. 24x12x4 is extremely big.............that's a 700whp intercooler.
I'd say, unless you're running 550whp daily, it's way overkill. You'd get quite a pressure drop across it if you're not running that much power.
Old May 9, 2008 | 06:49 AM
Schister66's Avatar
Man U FTW
Unless you're making an unreasonable amount of power, i would get a smaller intercooler. Just know that the larger the intercooler, the more air inside that has to be displaced before the engine sees boost....that means, the bigger the IC, the more lag.
EJ8 GSR-T
15
Jul 2, 2007 07:39 PM
integraboosted
Feb 1, 2007 03:53 PM
LSEGHATCH
Apr 16, 2005 07:45 PM
darylfiend11
Mar 22, 2004 12:59 PM
Ri5e
Jan 15, 2004 07:45 PM
