ARP rod bolts hitting main cap bridge on D16y8
Old 05-12-2008, 05:42 PM
Nichelson_Performance's Avatar
Default ARP rod bolts hitting main cap bridge on D16y8
hey guys I wasn't sure where to post this thread, but anyhow I'm building a D16, yes a single cam. I have a set of Eagle H-beam rods with the Vitara pistons to build my engine for high boost.
anyhow upon installing one rod/piston assembly to check for clearance (according to Eagle, minor clearancing is needed at the bottom of the cylinder walls to allow the assembly to rotate), well besides that, I also discovered something else that is a major problem it seems.
after installing the rod/piston and rotating the crank by hand, I discovered that the heads on the ARP 2000 bolts come in contact with the main bearing cap bridge and jam up.
does anyone have any recommendations as to what I could do to correct this problem? has any other single cam builder with this combo had this problem?
Old 05-12-2008, 06:06 PM
1badteg's Avatar
Default Re: ARP rod bolts hitting main cap bridge on D16y8 (Nichelson_Performance)
yes, this is normal. you need to notch it just like you notched the lower cylinder walls. I did this and it works perfectly.
Old 05-12-2008, 06:29 PM
Default Re: ARP rod bolts hitting main cap bridge on D16y8 (1badteg)
thanks, I wasn't sure what to do, I'm a former machinist and I thought about milling a small groove out of the bridge, but wasn't sure if it would affect the strength of the bridge.
i asked eagle what they thought about the situation, but they haven't gotten back about it yet
i guess the should include that in the description of the rods, oh well they are still almost three times as thick as stock rods
cmwalker
24
06-03-2012 05:39 AM
x-s-i-v
01-19-2012 06:21 PM
silverprop
08-13-2011 04:47 AM
HmgLauj69
03-21-2005 11:13 AM
B18EG6
06-30-2004 04:15 PM
Quick Reply: ARP rod bolts hitting main cap bridge on D16y8
