B18-t wont start
Old May 12, 2008 | 08:14 AM
Panda Eg6's Avatar
Default B18-t wont start
Ok so I had an OBD1 b16 that I pulled out that was turboed and running. yesterday I pulled the 16 and swapped in a b18b that I knew did run it is a 98 Obd2, and I cannot get it to crank over. It has fuel, and spark, the firing order is correct, I am going to double check the grounds. I am running a chipped p28 with a basemap chip (I tryed 2 other ECU's as well), an Obd1 ls dizzy, the same fuel rail with injectors from the b16, along with the harness.
Any Ideas? Thanks
Old May 12, 2008 | 03:23 PM
NJIN BUILDR's Avatar
Default Re: B18-t wont start (Panda Eg6)
Double check the tps plug and verify the color code.There are a few plugs that are the same shape and will plug into the wrong sensor.
Old May 12, 2008 | 09:45 PM
Panda Eg6's Avatar
Default Re: B18-t wont start (NJIN BUILDR)
ok, checked the grounds they are good, tomorrow I will check to see if the right sensor is plugged in the tps.
jmanjdm
Nov 10, 2014 10:42 AM
Eric724
Apr 28, 2011 06:23 PM
88 EF Hatch
Sep 4, 2009 08:51 AM
deryck324
Nov 2, 2006 08:22 AM
d15.hatch
Jan 30, 2006 10:49 AM
