engine immediatly floods wen i go to start
ok so i cant figure it out.. i go to start the car and it immediatly floods out wen i go to start it... i have changed the map sensor, changed the ecu, and the ostrich.. the car is tuned on crome and is a turbo b16.. the only thing that i can think of is the pick up in the dizzy is messed up.. does any one no what cud be goin on
Re: engine immediatly floods wen i go to start (dbiker207)
all 4 cyl do it.. the odds of all 4 injectors being stuck open at the same excact time is slim to none.... but i dont knpow...
Re: engine immediatly floods wen i go to start (418whpturboD)
ok so i changed dizzy and figured out that the injectors are staying held wide open only when power is to them... but still i cant get it to start
I know you've stated that you've changed ecu's and ostrich's, but in the past I've had similar problems and it came down to Crome and the particular bin I was using. Try loading another bin or just make a quick basemap and see if that works. Also, have you made any changes to crome in your laptop...updates, etc?
Yea def. sounds like an injector problem, almost sounds like its in the tune. What injectors are you running? Sounds like on start up the computer is telling the computer is opening the injectors wide open.....
Re: engine immediatly floods wen i go to start (turbo_zo)
New guy here . I have a 1999 integra ls doing the same thing. Maybe were trying to chase a similar issue. When it starts to crank the injectors go 100% and just dump as much fuel as they can right?
bmbarnum
04-13-2011 05:17 PM
1_BAD_RSX
Engine Management and Tuning
09-25-2009 06:50 PM
JalopySiR
03-12-2003 10:52 AM
