turbo feed line(d16z6)
i'm trying to figure out the best way to run the feed line to the turbo on a d16z6
i know it's a bad idea to run it from the oil pressure sensor on the back of the block to the front is there a port ,or a spot i can drill and tap out to feed it?
thanks in advance
thanks in advance
Re: turbo feed line(d16z6) (evokidvii)
becasuse it's just not a good idea to have an oil line open to debris,no matter how small ,plus it would be a pain in the azz to run it from the back to the front
Re: turbo feed line(d16z6) (beana)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beana »</TD></TR><TR><TD CLASS="quote">becasuse it's just not a good idea to have an oil line open to debris,no matter how small ,plus it would be a pain in the azz to run it from the back to the front</TD></TR></TABLE>
cmon dude, that just doesnt make sense. if you are afraid of the stock oil pressure port, get a snadwich adapter
Re: turbo feed line(d16z6) (dpetro1)
Where is the open line?? there isnt one, and it isnt a pain in the *** to run the line from the back to the front 3 feet of braided stainless, a dual take off fitting to screw in place of the oil press. sensor, thanks for coming out. its that simple
Thats really the only spot to get filtered oil w/o drilling. I use an adapter to change from 1/8" BSPT to 1/4" NPT compression, run a flexable copper 3/8" OD tube to a brass Tee bolted to the bottom of the intake. One side goes to the turbo, one to the pressure gauge, and drill another hole in 1/8" BSPT for the stock sender unit.
I dislike sandwich adapters because the cheap ones bypass oil around the filter, and the decent ones cost way more than they should.
Re: turbo feed line(d16z6) (HiProfile)
what is the best way to run it a hard 1/4in line under the distrubutor or a steel braded line from the tee to the feed?
