First time turbo set up
Old May 6, 2008 | 07:42 PM
jdmb18c1's Avatar
Default First time turbo set up
This is my first turbo set up, all the work will be done by myself and i will have inline pro performance shop in VA will do the tuning on the hondata s200 pictures will be posted up when completed but the engine is a mild set up my goal on the turbo would be 12-14 psi on the stock block but tell me what you guys think thanks.
*94 Civic hatch
*95 B18b 70K
** - inlinePRO Cast Iron Turbo Manifold
- Garett T3/T4 4 Bolt Discharge Turbo
- 2.5" down pipe kit
- Mirror polished aluminum charge pipes, couplers, clamps
- 24"x8"x3.5"(core size) front mount intercooler
- Greddy Type-S BOV
- TurboSmart 38mm wastegate
- Map Defensor, vacuum lines, fuel pump and Vortec FMU.
*inline pro head gasket
*hondata heat shield
*hon-data s200 tuned by inline pro
*arp head studs
*RC 450 injectors
*ngk plug wires
*ngk one step colder plugs
*crower adjustable cam gears
*stage 2 crower camshafts with valve spring and retainers
*Gsr tranmission
*fidanza stage 2 clutch
*mugen fan switch and thermostat
Old May 6, 2008 | 08:35 PM
averyvm's Avatar
Default Re: First time turbo set up (jdmb18c1)
nice man you got any pictures. I plan on turboin my hatch pretty soon. I just need some more bread.
hotimportcrx
May 23, 2005 08:15 PM
iHave2Cams
Apr 13, 2003 06:48 PM
The G2 Racer
Feb 4, 2003 01:49 PM
95hybridcivic
Jan 29, 2003 07:30 AM
