head rise
Old May 6, 2008 | 06:03 PM
scuffywin's Avatar
Default head rise
ok so i have a turbo 81.5 b16 using arp head studs, at 7 psi i have blown three headgaskets 2 oem/golden eagle and one cometic. I am torquing my arp headstuds to 85 ft/lbs with moly lube. Everytime i have replaced the gaskets i check for flatness with a straight edge and everything seems to be kosher, i have now pulled the motor and am separating it to get the block decked/ head milled just to be on the safe side. is there anything i am doing wrong/not doing so that when i put everything back together i will not have this problem again
Old May 6, 2008 | 06:11 PM
kyden's Avatar
Default Re: head rise (scuffywin)
how much timing are you running?
Old May 6, 2008 | 06:15 PM
scuffywin's Avatar
Default Re: head rise (kyden)
i think base timing is 15 degrees, i am not sure other then that the guy the tuned my car set all of that, is there a way i can look at my maps and tell you, i am running a s200 on a p28, it ran fine after then tune the headgasket problem has been a recent thing within the last couple of months
Old May 7, 2008 | 02:38 AM
scuffywin's Avatar
anyone help me out?
Old May 7, 2008 | 02:52 AM
atec's Avatar
can you post close up pics of your old spark plugs?(electrodes from the side and top) (They have to be detailed.
Old May 7, 2008 | 09:36 AM
scuffywin's Avatar
Default Re: head rise (atec)
yea ill do that when i get home
Old May 7, 2008 | 10:34 AM
morgan@synapse motorsport's Avatar
fyi stock HG are fine for 81.5mm GE doesnt need to overbore them.
Old May 7, 2008 | 11:31 AM
scuffywin's Avatar
Default Re: head rise (mike@synapse motorsport)
a stock b16 hg??
Old May 7, 2008 | 01:16 PM
yeah
Old May 7, 2008 | 05:59 PM
scuffywin's Avatar
ok so here are the pics of the plugs, these are the plugs from the first two oem/ ge headgaskets, they are in no particular order and no coolant in combustion chamer
these are the pics from the most recent cometic headgasket, again they are in no particular order and there was coolant in cylinder number one, and they were used for about two hours before the incident
Modified by scuffywin at 10:09 PM 5/7/2008
Old May 8, 2008 | 02:32 AM
scuffywin's Avatar
bump for some help
Old May 8, 2008 | 08:25 AM
EARLdaSQUIRREL's Avatar
official honda whore
sounds like something with the timing... btw you dont need to tq them that high, i have mine at 75 and no problems
Old May 8, 2008 | 11:05 AM
scuffywin's Avatar
Default Re: head rise (EARLdaSQUIRREL)
oh well i was only following what arp told me to torque them to
Old May 8, 2008 | 11:26 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuffywin &raquo;</TD></TR><TR><TD CLASS="quote">oh well i was only following what arp told me to torque them to</TD></TR></TABLE>
You might want to consider getting a new set of studs as yours are probably stretched....bad.
Old May 8, 2008 | 12:29 PM
scuffywin's Avatar
Default Re: head rise (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
You might want to consider getting a new set of studs as yours are probably stretched....bad. </TD></TR></TABLE>
yea good call
96accordsir
Dec 30, 2016 06:43 PM
Freshdot
Jul 10, 2012 06:06 AM
David27
Dec 10, 2007 08:56 AM
Turbowa
May 26, 2005 07:42 AM
