hondata,fuel injectors ? setup question
Old May 11, 2008 | 04:57 PM
Afrothunder_72's Avatar
Default hondata,fuel injectors ? setup question
So i am gearing up to turbo my 88 crx.. it has an ls motor in it.. but the question i have is it a requirement to get an "ecu upgrade"(as in hondata or uberdata) and upgrade the fuel injectors when adding a turbo? i have a fpr.. and shouldn't that be adequate as bigger injectors? i have a t3t04 turbo im putting on.. if you know the answer to this thanks
Old May 11, 2008 | 06:06 PM
SpoolnG2's Avatar
Default Re: hondata,fuel injectors ? setup question (Afrothunder_72)
No it is not adequate to just have a fpr. You need a bigger fuel pump, injectors, and a way to control the fuel and timing. So yes, you'll need the hondata,uberdata,aem,etc if you want to do it properly. Right along with a good tune.
DIRTYsouthBB6
Nov 8, 2007 08:23 PM
cutt
Apr 25, 2006 12:12 AM
DriveSlowHomie
Feb 18, 2005 11:59 AM
