anti-lag
Old May 11, 2008 | 09:14 PM
95dxsir2's Avatar
Default anti-lag
whats up all?
I'm putting my setup together and plan on 320-350whp. Is anti-lag out of the question? i plan on using this car more for strip than street. open downpipe and dump alittle past the drivetrain
Old May 11, 2008 | 09:23 PM
quicksilver1689's Avatar
i ♥ snails
what engine mangement are you using?
Old May 11, 2008 | 09:24 PM
95dxsir2's Avatar
Default Re: (quicksilver1689)
crome, my bad
possibly crome pro, would full throttle shift be good enough?
all i want to do is go the fastest i can with what i have....parts list in build thread
Old May 12, 2008 | 10:41 AM
TheShodan's Avatar
Moderator
Default Re: (95dxsir2)
The use of Anti-lag (I'm not including 2-step in this description), can be VERY dangerous for the use in the engine when used. 2-step is more than enough at a drag strip.
Old May 12, 2008 | 11:33 AM
95dxsir2's Avatar
Default Re: (TheShodan)
thank you, so anti-lag would be much better with a built bottom end? what about anti-lag set @ 7-8 psi when full boost would be @ 14-15? to much for a stock engine? B16
or do u think I'll be able to that with a 2 step?
Modified by 95dxsir2 at 12:52 PM 5/12/2008
Old May 12, 2008 | 12:42 PM
i ♥ snails
crome pro has anti lag?
Old May 12, 2008 | 05:35 PM
95dxsir2's Avatar
nevermind, i'm just gonna use 2 step and full throttle shift. thanks for the replies guys
Old May 12, 2008 | 09:50 PM
KeyserSoze's Avatar
Blythe?? LOL! I h8 that shitty little town. Worked at the power plant there for 4yrs, my dad still lives there.
What is your setup?? Anti-lag is a bit much for what you want. Two step should be just fine. 14-15psi at launch?? Dude, what kind of traction are you gonna get with that? Are you running slicks? What is your power level? Chances are, even gettin 7psi on a launch will be to much for reg street tires.
Old May 12, 2008 | 10:46 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">The use of Anti-lag (I'm not including 2-step in this description), can be VERY dangerous for the use in the engine when used. 2-step is more than enough at a drag strip.</TD></TR></TABLE>
indeed, it blew off my dump tube on my old set up...
Old May 15, 2008 | 07:52 PM
95dxsir2's Avatar
Default Re: (KeyserSoze)
yeah, this place is a **** hole unless your have a decent job. it still sux
no, i want 7 psi or so @ launch, not 14-15. yes i will be running slicks....street tires ftw
Old May 15, 2008 | 07:53 PM
95dxsir2's Avatar
my goal is 300 whp, but i would love to have 320-350 in a gutted 95 coupe
Old May 16, 2008 | 05:01 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">my goal is 300 whp, but i would love to have 320-350 in a gutted 95 coupe</TD></TR></TABLE>
Cool, yea the two step is what you need. Set that up and you should be golden. I have a 95 coupe to you may have seen it around last summer (Im out in the San Bernardino area now), but I didn't take it around all that much as I know there are a shitload of haters and theives out there.
GL man.
PS - You will likely be hard pressed to get 300whp @ 7psi of boost. It will likely take you between 9-12 to get there (on a safe tune anyway).
Old May 16, 2008 | 10:44 AM
95dxsir2's Avatar
what color is your coupe?
i imagine the psi will be around 14 or more......maybe
not that many thiefs out here, just ignorant haters
Old May 16, 2008 | 12:00 PM
.dave's Avatar
i HAS questions ?
Default Re: anti-lag (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">whats up all?
I'm putting my setup together and plan on 320-350whp. Is anti-lag out of the question? i plan on using this car more for strip than street. open downpipe and dump alittle past the drivetrain</TD></TR></TABLE>
Do you mean a 2 step? Anti-lag and 2 step are two different things. For a drag car all you really need is 2 step and some sort of full throttle shift control.
Old May 16, 2008 | 08:20 PM
95dxsir2's Avatar
Default Re: anti-lag (.dave)
no, i meant anti-lag.
Now i'm going to use 2 step with full throttle shift (Crome)....thats why i asked if anti was out of the question....a waste.
Old May 16, 2008 | 09:09 PM
HiProfile's Avatar
I'm always reminded of the guy who tried it with a full exhaust (chaimbered muffler), and blew the muffler out.
For 3-350whp on a B16, all you need to learn is to launch it correctyly. If you use Crome Gold, you will get a decent form of anti-lag, not to mention gear-based boost control. ECtune has a better anti-lag, as well as boost control.
Old May 16, 2008 | 10:44 PM
95dxsir2's Avatar
Default Re: anti-lag (HiProfile)
do you mean crome pro? and i'll be using turbo xs dual stage boost controller
Old May 17, 2008 | 09:26 AM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">what color is your coupe?
not that many thiefs out here, just ignorant haters</TD></TR></TABLE>
My coupe is a black ej1. And yes there are a shitload of haters, and a lot of thieves. Last year someone stole my STOCK ek. It did have si's and an si front end but thats about it. Morons. Still piecing that bitch back together.
ps - you shouldn't need 14psi of boost to hit 300whp on a 57 trim with a .63 a/r hotside. It should b a bit lower than that.
Old May 17, 2008 | 09:21 PM
hondamn1320's Avatar
don't mean to thread jack, but can anyone explain what full throttle shift is?
Old May 18, 2008 | 10:40 AM
95dxsir2's Avatar
you got your car stolen in blythe? wow.
about the psi, i've got a lower comp. ratio than stock, but i'm also thinking of pushing alittle more than 300whp. maybe 325 or so. (.074" headgasket)
hondamn1320.....fts is a set redline inbetween shifts and uses the clutch pedal as an input. I've searched and still haven't found how it exactly operates, but it is used to keep the boost pressure up while inbetween shifts.
so say your redline is 8,200k..you'd probably want the fts set @6k or so.
Old May 20, 2008 | 09:04 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">you got your car stolen in blythe? wow.
about the psi, i've got a lower comp. ratio than stock, but i'm also thinking of pushing alittle more than 300whp. maybe 325 or so. (.074" headgasket)</TD></TR></TABLE>
No the car was stolen in the IE, and that was my stock ek. I wouldn't want my ej1 stolen.......I would be trackin ***** down.
I am using a .074" hg as well. Cometic? In my gsr it gives me ~9.5:1 cr.
91b18a1ls
Engine Management and Tuning
Oct 21, 2015 07:41 PM
mtflyboy25
Jul 13, 2013 07:01 PM
mike93eh2
Aug 30, 2007 08:17 PM
congo
Honda S2000
25
Jan 30, 2006 05:11 AM
ITRnorway
Jan 18, 2005 01:17 PM
