crankcase thought..
Old May 10, 2008 | 08:11 PM
londoncivic's Avatar
Default crankcase thought..
I'm sort of torn between an idea. Well im sick of smelling the crank gases since im running open pcv and valve cover ports. I know in a boosted honda u need ventilation but it smells and gives me a headache. What im thinking of doing is hooking back up the stock PCV with a check valve to make sure boost doesnt get thru, and the valve cover nipple right to pre turbo intake. I know this will be fine for low load but for higher load think ill be ok? Im just running 7 psi...what do you guys think will it be sufficient enough?
Old May 10, 2008 | 08:15 PM
rmcdaniels's Avatar
Default Re: crankcase thought.. (londoncivic)
Moroso makes a kit with a venturi tube and a check valve that creates a vacuum to suck the crankcase gases into the exhaust. It's cheap and works well on my car. That way you have no crankcase gases into the intake.
Old May 10, 2008 | 09:09 PM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londoncivic &raquo;</TD></TR><TR><TD CLASS="quote">What im thinking of doing is hooking back up the stock PCV with a check valve to make sure boost doesnt get thru</TD></TR></TABLE>
Aren't PCV valves basically just check valves anyway?
92hatch_cx-t
Mar 12, 2007 02:53 AM
mastamind
Oct 4, 2006 02:36 PM
Bambooseven
Sep 22, 2004 10:51 AM
streetracinghn
Nov 23, 2003 06:21 AM
