GSR TURBO SYSTEM SETUP
Old May 13, 2008 | 07:39 AM
9818tegr's Avatar
Default GSR TURBO SYSTEM SETUP
i want 2 turbo my 98 gsr.. i only want 5-7psi so im hopeing i can do it simply and safe, reliable, cheap.. idealy i am hopeing to NOT have to get it tuned anytime soon and be able to safely drive it daily. i want it to be safe to the engine/turbo/car most important.. second reliability is important.. third i want it cheap as possiable.. i know that safe , cheap and reliable in a turbo system is not easy to come by, if at all possible.. im just looking for some advice as to the best system and ideas.. im looking to buy used parts [hopefuly all good], to keep cost a little lower.. i have a little knowledge in this, but ive been outta everything 4 a few years, so im rusty on my info.. THANKS JM
Old May 13, 2008 | 08:01 AM
chimmike's Avatar
Default Re: GSR TURBO SYSTEM SETUP (9818tegr)
FAQ's are your friend.
If you are not looking to get it tuned, don't go turbo at all!
Old May 13, 2008 | 08:11 AM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9818tegr &raquo;</TD></TR><TR><TD CLASS="quote">i want 2 turbo my 98 gsr.. i only want 5-7psi so im hopeing i can do it simply and safe, reliable, cheap.. idealy i am hopeing to NOT have to get it tuned anytime soon and be able to safely drive it daily. i want it to be safe to the engine/turbo/car most important.. second reliability is important.. third i want it cheap as possiable.. i know that safe , cheap and reliable in a turbo system is not easy to come by, if at all possible.. im just looking for some advice as to the best system and ideas.. im looking to buy used parts [hopefuly all good], to keep cost a little lower.. i have a little knowledge in this, but ive been outta everything 4 a few years, so im rusty on my info.. THANKS JM</TD></TR></TABLE>
hoping to not have it tuned? can you clarify a bit.
Old May 13, 2008 | 10:51 AM
9818tegr's Avatar
Default Re: GSR TURBO SYSTEM SETUP (mike@synapse motorsport)
i was hopeing to be able to set it up where i dont have to take it stright to get it tuned... is that possiable?
Old May 13, 2008 | 10:53 AM
chimmike's Avatar
not if you're looking for it to be safe and reliable, without being piggishly rich and making carbon build up on the pistons.
Can't have cake + ice cream and eat it without utensils, if you get what I mean.
Old May 13, 2008 | 11:25 AM
9818tegr's Avatar
Default Re: GSR TURBO SYSTEM SETUP (chimmike)
i kinda thought that was the case.. so i guess ill have to get it tuned, because safe and reliable are nessary.. how much tunein u think it would take, in dollars.. roughly.. i still need a good idea of what all i must have, and maybe some thoughts..
Old May 13, 2008 | 11:32 AM
chimmike's Avatar
http://www.phearable.net
he's right up in NPR, does great tuning.
FAQ's
Old May 13, 2008 | 11:38 AM
9818tegr's Avatar
im on the east coast, i was hopeing i could find someone over here.. can i drive it to get tuned or is that no good also?
Old May 13, 2008 | 11:39 AM
chimmike's Avatar
if you run stock ecu and injectors only to the tuner, don't get in boost at all, yeah.
i'm sure there's a tuner near you. see the directory.
Old May 13, 2008 | 12:35 PM
9818tegr's Avatar
i know the basic parts, turbo, manifold, wastegate, bov, intercooler... what else do i need to make it a safe reliable system? what do i need for tuneing?
Old May 13, 2008 | 12:36 PM
9818tegr's Avatar
also what will it cost roughly to tune, how much time?
Old May 13, 2008 | 02:46 PM
WGFletch4WS's Avatar
tuning prices depends on the tuner id say the average street tuning is about 75-90$/hr and assume atleast 3hours of tuning or so
sounds like u got alot to figure out before u even have to worry about how much tuning is going to cost tho like an actual power goal
Old May 13, 2008 | 03:02 PM
9818tegr's Avatar
Default Re: (WGFletch4WS)
im looking for less of a "power goal" and more so just want a safe reliable system, like 5-7 psi is fine..
Old May 13, 2008 | 03:34 PM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: (9818tegr)
Well, you HAVE to base it on a power goal. 5-7psi will mean completely different numbers and characteristics on different turbo's. Not everything, in fact nothing really matters as far as psi goes until you have figured out what setup you want to stick with. Figure out what turbo you want, and figure out how much power you want.
Yes, the search is down, but you CAN find threads on google as well. This has been covered so many times it's ridiculous.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9818tegr &raquo;</TD></TR><TR><TD CLASS="quote">i know the basic parts, turbo, manifold, wastegate, bov, intercooler... what else do i need to make it a safe reliable system? what do i need for tuneing?</TD></TR></TABLE>
Oil feed and return, injectors, depending on power level fuel upgrades (Walbro 255)
For tuning, a form of tuning software, whether you go with crome, hondata s200, s300, You need different things. looks like crome MIGHT be your best bet though because it seems you are very conscious of funds.
http://www.pgmfi.org READ READ READ, and research for hours and hours and you will figure it out.
Look in the marketplace for used parts as well. Good Luck
Old May 13, 2008 | 05:25 PM
9818tegr's Avatar
Default Re: (GT35R_EF)
thanks for the info.. as far as the turbo goes i want quicker spooling as apposed to top hp, im thinking like a t3 t4 maybe, not real sure bout housings and fans.. what would u recomend for my situation??
Old May 14, 2008 | 06:27 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9818tegr &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info.. as far as the turbo goes i want quicker spooling as apposed to top hp, im thinking like a t3 t4 maybe, not real sure bout housings and fans.. what would u recomend for my situation?? </TD></TR></TABLE>
AND once again it goes back to the question of the power goal. T3/T4 has MANY different designations.. I have a feeling you're looking for the 250-300whp level only. PSI means nothing with the wrong turbocharger. Have you checked other setups to see what may work for you? Check w/ Schister66 and his setup. Might be what you're looking for.
Old May 15, 2008 | 05:40 AM
Default Re: (TheShodan)
just choose a damn power goal already like i said..u must have some number in ur head
Old May 15, 2008 | 05:55 AM
chimmike's Avatar
didn't we say to start reading the FAQs?
I mean, if you haven't looked at those yet, you REALLY REALLY SHOULD. Then you'd answer your own questions with a little research.
Handing you info on a silver platter won't help you if you come across a common problem while boosting.
Old May 15, 2008 | 07:49 AM
9818tegr's Avatar
235-265hp, im not looking for alot of power.., a quick response setup is what i want..
Old May 15, 2008 | 07:51 AM
9818tegr's Avatar
Default Re: (chimmike)
yeah, whats a FAQ?? no i have not read it, id love to if u explain what and where these FAQ's are?
Old May 15, 2008 | 08:10 AM
GT35R_EF's Avatar
Well, it's very simple actually. maybe this is the problem with so many repetative questions in here; maybe they just can't find the FAQ's page!!!
List of instructions...
1. Click on the forced induction forum page
2. Click on the first stickied post titled Forced induction forum FAQS.
I know, it's tough....
Modified by GT35R_EF at 9:17 AM 5/15/2008
Old May 15, 2008 | 08:12 AM
chimmike's Avatar
ROFL.
I didn't know it was this hard.
FAQ=Frequently Asked Questions (yours)
Old May 17, 2008 | 09:23 AM
9818tegr's Avatar
ive looked a little bit, but i dont fully understand everything yet.. im thinking i want a to4e 54 trim turbine wheel.. i thinking like 230ish hp at 6psi.. what do yu think??
Old May 17, 2008 | 05:24 PM
Silva Bullit DC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9818tegr &raquo;</TD></TR><TR><TD CLASS="quote">im looking to buy used parts [hopefuly all good], to keep cost a little lower.. </TD></TR></TABLE>
When attempting a turbo project, it is wise NOT to cheap out with used parts. Buy new products that way you KNOW what you're getting. There are tons of good turbo parts and accessories right on this website (sponsor's forum) at nice affordable prices. Conduct some more searching, talk to some of the gurus on here thru PM or e-mail, check out some of the many build threads right in this FI forum and good luck with the build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9818tegr &raquo;</TD></TR><TR><TD CLASS="quote">ive looked a little bit, but i dont fully understand everything yet.. </TD></TR></TABLE>
Keep looking. Search is your friend. Use keywords on things you wanna know about. There's tons of info on here, it just takes a little time. But sit back and READ, READ, READ, you'll find the answers you're looking for.
Modified by Silva Bullit DC4 at 6:32 PM 5/17/2008
jordan_civic
Oct 5, 2007 11:33 PM
vtec_racer_2kgsr
Oct 25, 2006 09:12 PM
Hybridwill
Dec 6, 2004 09:47 AM
Gsr94black
Nov 15, 2004 09:19 PM
xstalkrx
Jun 27, 2004 03:37 PM
