Car bogs when hitting boost
Old May 7, 2008 | 03:50 PM
98jdmcivic's Avatar
Default Car bogs when hitting boost
I have a bogging problem, my car bogs mainly when i reach boost. sometimes while normal driving I can feel it bog down, then i let off the gas and apply pressure to the pedal it goes away for a little while then back again. I pulled the plugs and they were carboned over, which tells me it is running rich. could be the distributor not putting out enough spark. I tested the components by the book, and everything checks out fine, I was gonna swap the ICM but mine is stuck in the housing. any help?
Old May 7, 2008 | 04:54 PM
98jdmcivic's Avatar
Default Re: Car bogs when hitting boost (98jdmcivic)
I have swapped the map sensor out also, and no luck.
Old May 7, 2008 | 05:06 PM
TurboDelSolEH6's Avatar
What are you using for Tuning???
Old May 7, 2008 | 05:19 PM
omiehomie's Avatar
Default Re: (TurboDelSolEH6)
im confidant (80%) you are having fuel problems is your car tuned? what do your afr's look like
Old May 7, 2008 | 05:28 PM
98jdmcivic's Avatar
Default Re: (omiehomie)
I had it tuned with hondata, it ran great for about two weeks aside from some issues with the fuel system. after a day of racing it pretty hard it starting boggin like i explained earlier. I have the stock ignition on their, replaced the plugs. What else would cause it to run rich?
Old May 7, 2008 | 06:16 PM
b20turbocivic's Avatar
Default Re: (98jdmcivic)
i am currently having the same problem change out distributor,fuel pump,fuel filter and and regulator and car still bogs when driving
Old May 7, 2008 | 06:42 PM
Schister66's Avatar
Man U FTW
It may not be the problem, but what are your plugs gapped at and do you have pictures of them?? Which ones are you running?? I had problems after my tune and once i got a set of NGK BKR7e's gapped correctly, my problems went away. I was having spark blow-out problems.
Old May 7, 2008 | 08:02 PM
HiProfile's Avatar
Default Re: (Schister66)
Have you done a compression or leakdown test? I'd almost guess you have a headgasket, ring, or piston problem now. Usually if your engine starts runs bad and all you do to 'change' the setup is run it hard, something is broken. If it was just a fuel system problem, it would bog in places besides boost too.
Old May 8, 2008 | 02:37 AM
98jdmcivic's Avatar
Default Re: (HiProfile)
I am running NGK BCPR7es plugs gapped at 28. I get the boging sometimes under normal driving conditions, could it possibly be bad gas, when i changed my fuel filter the fuel came out like muddy water. my tank was/is badly corroded, due to the shop i took it to did not care for it like they should have. i am doing a compression test after work today, but sometimes the car boosts up to 5 lbs. I dont have much time to work on it to troubleshoot it, but this is getting crazy. by the way thanks for the replys, let me know any other inputs.
I put new plugs in the car and then i checked them a few days later and they had carbon all over them.
Modified by 98jdmcivic at 4:30 PM 5/8/2008
Old May 8, 2008 | 05:53 AM
hey 98jdmcivic does your motor flood out on you sometime when you try starting it?
Old May 8, 2008 | 12:57 PM
98jdmcivic's Avatar
Default Re: (b20turbocivic)
well I am not really sure, it is hard to start sometimes. how can you tell? Also I was talking to some guys at work and someone mentioned it might be the computer going out. what are the chances of that happening? To fully explain my situation please check the link to another thread. https://honda-tech.com/zerothread?id=2265757 you may have to copy and paste it into the address bar. this gives a good history of my car and situation. please let me know any other things to check. and thanks again
Old May 8, 2008 | 06:02 PM
well when you pull out the plugs after you start it can you see gas on them im having the same problem as you are i was thinking it might be my ecu to but the light on my hondata stays solid so im guessing nothing is wrong
Old May 9, 2008 | 02:26 AM
98jdmcivic's Avatar
I will have to check that out, also i guess i will have to read up on the hondata systems. but if you read that link i posted, by the way that shop handled my car, it could be anything.
Old May 12, 2008 | 03:17 AM
98jdmcivic's Avatar
Anyone know if there is a way to test the socketed ecu's, or hondata box, or both.
vtisturbo
Dec 18, 2020 04:25 AM
focuz_btch
Jan 23, 2009 08:29 PM
angela_itr
Apr 11, 2005 09:48 AM
cliff666
Aug 1, 2004 11:04 AM
scooter
Mar 1, 2003 06:25 PM
