Shooting for 425 whp.
Old May 4, 2008 | 07:21 PM
Rooftop voter's Avatar
Default Shooting for 425 whp.
I'm currently having the motor built. Here's the setup.
b18b block:
Eagle H beams
JE 9:1 pistons
OEM bearings
Balanced crank
B16 head:
Supertech valve train
P&P
multiangle valve job
Turbo:
Garret 60-1
Turbonetics log mani
3 inch DP
3 inch exhaust
Hondata s200b
There's more stuff but here's the most important things. My goal is eventually going to be around 425whp on my LSVT build, but what do you think it will make the way it is right now? I'm hoping to be at least around 380 whp for now then up to 425 or so after a ramhorn and a victor x intake mani. What cams would you guys use for something like this, or should I just stay on the stock b16 cams?
__________________
Old May 4, 2008 | 08:25 PM
Runnerdown's Avatar
Default Re: Shooting for 425 whp. (Rooftop voter)
Get a good manifold, ditch the log. Get some mint used gsr cams.
Old May 4, 2008 | 09:06 PM
Default Re: Shooting for 425 whp. (Runnerdown)
Why GSR over b16? Yeah, I'm gonna ditch the Log as soon as I have more cash that I can use for it. I'm gonna try to find one that's AC compatible, but if I can't (or can't afford it) I won't worry about it.
Old May 4, 2008 | 09:41 PM
quicksilver1689's Avatar
i ♥ snails
i would go with the inline pro cast mani, its made over 700whp on one setup so its good enough for you, yeah b16 cams are pretty much at the bottom of the stock b-series cams, gsr or itr's will help it move air more efficiently. but dont get me wrong you can do it with stock cams no problem.
Old May 5, 2008 | 01:39 AM
h2b_sedan's Avatar
Default Re: (quicksilver1689)
well my b16 made like 415 on 15 psi and its just got 9:1 pistons, gsr cams, a victor x intake mani, and a custom ram horn. so you should have no problem at all making 425. just depends on the capabilities of the tuner. but thats just my 2 cents.
Old May 5, 2008 | 03:53 AM
atec's Avatar
I hate the old scool s200 after s300 came out.
but that is my opinion as a tuner.
With the new v4 program it will work just as well.
Your setup looks sweet.
You dont need the Port and polish for your hp goal, but if you do only look for the most reputable shop, and not some backyard porters.
get yourself the inline pro manifold, or the F-R ramhorn.
(with the F-R ram, and example a .82A/R you can take advantage of the scavenging with the s2s1 or s2pro1 cams)
I have not used the inline before but Ive seen good results.)
Also think about calling Tony (T1) or Jeff Evans to a tuning apointment.
Modified by atec at 5:00 AM 5/5/2008
Old May 5, 2008 | 05:45 AM
Default Re: Shooting for 425 whp. (atec)
Thanks for your input. I am having the motor built by slowmotion motorsports here in Columbus, they specialize in modified hondas so hopefully they know how to properly P&P a head. Other than datalogging and such, what is the s300 going to be able to do that the s200 can't do as far as tuning? It's going to be tuned by Corey Parish at Slowmotion aswell. Thanks, Ramsey.
Old May 5, 2008 | 06:27 AM
GT35R_EF's Avatar
Make mine whatever you want
The S300 has a lot of stuff over the S200...
S200 Features: http://hondata.com/s200.html
S300 Features: http://hondata.com/s300.html
Old May 5, 2008 | 09:37 AM
Default Re: Shooting for 425 whp. (GT35R_EF)
What do you guys think the setup will make as it is right now with the log mani?
Old May 5, 2008 | 11:47 AM
GT35R_EF's Avatar
It's hard to say exactly man, but make sure to read the forum rules, people ask this all the time. Search for similar setups and see what they make thats the best I can say, or anyone can do here. Strap it on the dyno and find out, the "e-dyno" is never accurate. good luck.
rdssk8rcs1
May 12, 2011 07:40 AM
93egSLEEPER
32
Dec 24, 2009 03:26 PM
abusedhusband
15
Jun 18, 2007 09:34 PM
First Swap
Jan 18, 2007 04:48 PM
