integra coilovers on civics?
Old Jun 20, 2001 | 04:03 AM
PolosportZ81's Avatar
New User
Default integra coilovers on civics?
just wondering if 98 integra ls coilovers and shocks will fit my 98 civic ex.....
anybody?
thanks
Old Jun 20, 2001 | 05:07 AM
keithv's Avatar
Default Re: integra coilovers on civics? (PolosportZ81)
They should fit, but the ride might be a bit harsher on the Civic since it weighs less than the Teg.
Old Jun 20, 2001 | 09:03 AM
Asahi's Avatar
Ground Control like Coilovers or true coilovers?
Old Jun 20, 2001 | 09:30 AM
Kalokohan's Avatar
New User
Default Re: integra coilovers on civics? (Carlex)
What's an example of a true coilover?
Old Jun 20, 2001 | 11:38 AM
New User
Default Re: integra coilovers on civics? (Unleashed5GHBGS-R)
GC....thanks for all that posted....so i guess i can us the GC but can't use the shocks...bummer.....
Old Jun 20, 2001 | 11:46 AM
BuiltbyFFEJ's Avatar
Banned
you can use the shocks and coilovers for the fact that all 94+ integras 92-95 civics and 93-97 delsol take all the same strut but the 96+civics say they take a different strut yeah the part numbers are different but the only difference is in the rear strut all you have to do is add 2 space washers to the bottom of each strut is all you need because the rear lower control arm on the 96+ civics is smaller than the 94+ integras-------so if you order stuts from tokico the difference in part numbers is this HU3713 and HU3713A all they do from tokico is throw two washers in the box thats all so to answer your question is "YES" they will fit!!
Old Jun 20, 2001 | 04:15 PM
Jesse H's Avatar
your stock suspension is a "true coilover," FYI.
Spring sits around the damper.
onepoint-gsr
Suspension & Brakes
Sep 1, 2006 10:42 AM
Unit44justin
Oct 9, 2005 07:10 PM
DissidentCivic
Jan 19, 2004 06:54 PM
JDubya
Apr 15, 2002 02:57 PM
