MSD Igntions
Old Jun 18, 2001 | 07:20 PM
Max GSR's Avatar
Default MSD Igntions
Anybody using one?
Good/bad experiences?
What model(s) & setup?
thanx.....
Old Jun 19, 2001 | 10:37 AM
Max GSR's Avatar
Default Re: MSD Igntions (Max GSR)
Now really..... I can't believe that NOBODY is using MSD ignition systems here???? Anybody?
Old Jun 19, 2001 | 11:26 AM
Halo's Avatar
After getting my cams, high flow fuel pump and Injectors installed my car had a tough time burning the extra gas. I bought a MSD 6AL, Blaster 3 coil, MSD cap, Beru spark plugs and Nology wires. My gas mileage improved dramatically, as well as my throttle response. I would highly recommend getting this set-up, it has been worth every penny. If your not to good at wiring check out Holley's Annihilator line of ignitions, they all use plug and play technology. If your car doesn't have any internal mods, then save your money for something else
Old Jun 19, 2001 | 11:44 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: MSD Igntions (Halo)
I dont need one with my turbo..
art
Old Jun 19, 2001 | 12:04 PM
Max GSR's Avatar
AhHa - that's the kind of response I was hoping for! Yes, I've done quite a bit of work to the engine & I suspect I'm not burning all the fuel I'm supplying & just curious if anyone had experienced a noticeable difference, as you have described.
I'm leaning towards the SCI model as it seems more suited to a 9k revving motor and I don't need a rev limiter. As for the coil, why a Blaster 3 instead of a Blaster 2? Also does an Integra need a coil with a ballast?
Any recommendations on less expensive sources for the MSD stuff??
thanx...
Old Jun 19, 2001 | 12:15 PM
Halo's Avatar
Dewd DO NOT GET THE SCI MODEL!!! I know someone who had it and was very let down, I bought my 6AL from summit for like $140, The Sci is a $260 6AL all the same features. Also your plug wire choice should be carefully considered, After using NOLOGY I will never use anything else
Old Jun 19, 2001 | 02:30 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I have the 6AL with my GSR with CTR cams and so on. IMO, it won't do a thing unless you are running around 200whp. The stock ignition will work fine. I originally bought the 6AL to resell but I got an itch to install it, so I did. I am running Magnecore wires with it. Result: Idle felt a bit better and response seemed better as well. But after driving it for a few more months I don't really feel it is a necessary item with the mods I have.
Was it a waste of money? Yes and No. Yes, for the price I got it for. No, I wouldn't waste my money on one again. I can make a few bucks if I ever get off my duff and un-install it. You can probably just improve spark by advancing your timing, getting new wires and plugs and a new cap and rotor. Things you should change anyways.
I have friends running JDM R-spec engines with the stock ignitions so I don't see the need for one... Of course this is after I already got one. Save your cash.
Old Jun 19, 2001 | 03:31 PM
93B18's Avatar
Default Re: MSD Igntions (Gee3)
My LSVTEC motor being built as we speak is gong to be running 11.3:1 compression via Endyn Rollerwave pistons and CTR cams and I will be using a B&M FPR & gauge set and RC cleaned and balanced 246cc injectors. Do you think I would need a 6AL b/c of the increased compression and fuel going into the cylinders?? I will be running magnecore 8.5s, changing the dist cap, rotor and plugs. TIA.
Old Jun 19, 2001 | 09:26 PM
94gsr's Avatar
The SCI model is just a way for MSD to make $$ off of the import crowd. The SCI-L is the model that is around $240. The SCI has the same features as the 6A, but the 6A is $40 less. For the same price as the SCI, you can get the 6AL which has all the features of the SCI, plus the "soft-touch" rev limit feature which is a very good thing. If you get one, go 6AL. Of course, the pills for the rev limit are around $25, but you don't NEED to incorporate the "soft-touch" if you don't want. If you're pressurized, or have increased compression, get one.
I'd recommend getting it from Summit, unless of course, you can find it on thepartstrader.com, or maybe a group buy for one.
Old Jun 19, 2001 | 09:36 PM
Halo's Avatar
Default Re: MSD Igntions (94gsr)
http://www.summitracing.com has the 6AL for $170. The igniyion comes with 5 different RPM pills 4,5,6,7 and 8k. Oh yeah if you call ask to speak with Clark, Dean is a major *******
[Modified by Halo, 6:37 AM 6/20/2001]
Old Jun 19, 2001 | 10:06 PM
94gsr's Avatar
Oh yeah. But it's the 3, 6, 7 & 8k pills that are included. Well, that's what the site says anyway...
Old Jun 20, 2001 | 12:42 PM
Max GSR's Avatar
Halo - here is the response directly from the MSD engineers when I asked them the difference between the SCI and 6AL models:
The MSD 6AL and the MSD SCI PN# 6320 are the same unit, the only deference is the color of the case.
Of course he doesn't mention that the SCI model costs more!
Old Jun 20, 2001 | 01:16 PM
94gsr's Avatar
Yeah, costs more to the tune of $100. It's amazing how everyone has to try to rip off the import crowd...
radicaled434
11
Jan 23, 2009 09:16 AM
jsnm
Nov 10, 2005 10:39 AM
99SlammedCivic
17
Nov 30, 2003 07:30 PM
Smith Wise
Feb 17, 2003 10:15 AM
LillDragun
Nov 7, 2002 12:19 AM
