Wut!? How to change Transmision fluid
I thought the "correct" fluid level was right at the fill plug opening. I opened it to check the level and replace my fluid and it came puring out. Was this because the car was jacked up? Should I just drain it and fill it to the hole?
Re: Wut!? How to change Transmision fluid (sackdz)
You should keep the car level when filling the tranny fluid. If you had the front end jacked up, some fluid should come out.
And you opened the fill plug right? The 17mm one, <U>not</U> the 3/8" sqaure plug...
Re: Wut!? How to change Transmision fluid (breaka_1_9)
I figured I should jack up the back... too lazy. I filled it up with the car slanted, will that be too little fluid..???
I did the same thing...filled up the tranny fluid with the front only jacked up. Everything seems fine right now, but I'll probably go back and fill it some more with the car leveled off...
this might help you:
http://www.c-speedracing.com/howto/t...ransfluid.html
good luck if it doesnt
Alex
Alex
Moosa S
Honda Civic (2006 - 2015)
11-13-2018 03:19 PM
JennyPooh
40
11-04-2010 11:17 PM
jdmstyleEJ6
05-02-2010 10:24 AM
