Highest flowing header for LS?
Old Jun 22, 2001 | 12:34 PM
Halo's Avatar
Default Highest flowing header for LS?
I called JG today and Nancy is claiming their JG header makes 18 whp!! Is this true? I have a DC 4-2-1right now, and I know I can do better, since it is non-vtec what do you guys suggest?Thanks
Old Jun 22, 2001 | 01:04 PM
2000LS-Vtec's Avatar
New User
Default Re: Highest flowing header for LS? (Halo)
Yup... Its true JG Engine Dynamics teamed up with Edelbrock and now together they are going to produce some great products.
Check it! http://www.edelbrock.com/automotive/index.html
Also about the there new header. Here is a link that will make you happy!
http://www.jgenginedynamics.com/proflo
Old Jun 22, 2001 | 01:26 PM
HX_Guy's Avatar
Default Re: Highest flowing header for LS? (2000LS-Vtec)
Man Im sorry..but I really dont think ANY header will make those kind of gains on a stock engine.
13 HP gain over DC headers near redline? 8 ft-lbs of torque too?
Old Jun 22, 2001 | 02:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: Highest flowing header for LS? (HX_Guy)
You might want to consider a JDM spec header with a 2.5" collector. As far as I know, a header designed for an ITR should fit your car with little or no modification. Of course with the 2.5" collector you will need either a testpipe, larger cat, or a modified stock cat. A JDM spec header should provide a good deal more performance than any US spec one, assuming your car needs the greater airflow. The new DC JDM 4-1 seems to be a good low-cost choice thats apparently similar to the Mugen piece in design.
Old Jun 22, 2001 | 11:15 PM
sLo B18b's Avatar
New User
Default Re: Highest flowing header for LS? (SpecR0123)
how much does this header cost??? i was also considering buying this because edlebrock is kinda known for making headers for domestic v8's..well at least that is mostly what i hear about...... when it comes to headers on a v8
Old Jun 23, 2001 | 10:48 AM
Padawan's Avatar
Darth ModerVader
Default Re: Highest flowing header for LS? (sLo B18b)
SLo - The JDM DC comes in either ceramic coated or stainless steel. I know at one point the S/S headers were not available but I'm not sure as to current availablity. The CC headers can be found for right around $300 shipped. I don't know the best prices on the S/S models but it should be around what the USDM DC stainless headers go for. Also figure in the price of a testpipe, new cat, or flange to modify your existing cat. You'd be much better off either running a larger high-flow cat or a testpipe rather than modifying your stock cat though. The stock cat would definately become a bottleneck in the system.
Old Jun 23, 2001 | 10:51 AM
Padawan's Avatar
Darth ModerVader
Oops, just re-read your post and now I'm not sure whether you were asking about the DC or the Edlebrock.
Old Jun 23, 2001 | 10:55 AM
BlackGSR's Avatar
I'm pretty sure that the LS can use an ITR header. The GSR is the only model, which has a different cat (shorter), different exhaust (longer), and different header (longer). haha - confusing.
Anyhow, back to your question. A JDM spec header will be your best bet. A Toda or HyTech header are probably the BEST header money can buy. They will just destory that domestic header.
Old Jun 23, 2001 | 07:43 PM
newspeedR's Avatar
ok, so were can you find it for 300 shipped??
Old Jun 23, 2001 | 09:17 PM
jbsadler's Avatar
New User
Default Re: Highest flowing header for LS? (BlackGSR)
If I were to get a JDM ITR header, what is the best cat to use for it and how much do the cats usually run? Also, is it hard to install a cat, because most of the ones I've seen, you have to weld on the flanges>>Is there one that you don't have to do any welding that will bolt on to the ITR header and a 3" cat-back exhaust?
Old Jun 23, 2001 | 10:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: Highest flowing header for LS? (newspeedR)
Check with Boba-Fet, I know he said his was roughly $300 shipped for the CC but I forgot where he ordered from. Most agree that the Carsound cats are the prefered cats to use. There are a few places that offer bolt-on cats for Integra applications - IPS racing and SMSP are two that I know of. Most people use the 2.5" cat, but for my car I would most likely use the 3" model. I'd rather not use a cat at all, but the 3" seems to be the largest available and will flow more than the 2.5". I'm sure the 2.5" cats are sufficient though, or people wouldn't use them. I just figure I'm only going to buy the cat once (hopefully) and I might as well get one that will never become the restriction in my system, regardless of my mods.
Old Jun 23, 2001 | 10:21 PM
sLo B18b's Avatar
New User
actually i was talking about the JG Edlebrock header........ i dont want JDM.... i dont wanna have to do any mods just for a header....
Old Jun 23, 2001 | 10:31 PM
Halo's Avatar
That JG header costs $500+, plus if you want that B-pipe they advertise for it that's an additional $250. YIKES
tempsohc
Nov 18, 2007 10:01 AM
boosted94teggy
Sep 19, 2005 11:25 PM
blu3g
May 25, 2005 02:26 PM
Ryuji
Jan 28, 2002 03:42 AM
CRX_VTEC
Jul 28, 2001 06:11 PM
