does shaving a head do a big difference
Old Jun 18, 2001 | 07:45 AM
tsjag17's Avatar
New User
Default does shaving a head do a big difference
i have a 2000 gs-r with type r cams, aem cam gears, comptech headers, iceman cold air, and a greddy evo cat back exhaust... i sent my head to be shaved 40thousands. should i feel a big difference and what do u think my number should be at? thanx for the info
Old Jun 18, 2001 | 09:26 AM
E Swift's Avatar
Default Re: does shaving a head do a big difference (tsjag17)
You'll notice a little difference.
Old Jun 18, 2001 | 09:41 AM
GSRwBOOST's Avatar
Default Re: does shaving a head do a big difference (420TegLS)
i have had a flat top before.. but i dont think shaving it will get you many women...
Old Jun 18, 2001 | 01:00 PM
berkel's Avatar
Default Re: does shaving a head do a big difference (GSRwBOOST)
Hi,
I think the rule of thumb is .1 compression point for each 10 Thousandth milled. "Shaving" is like milling, right? For example, you would gain .4 compression points ceteribus paribus. 1 compression point is worth roughly 4 % TQ across the board, so you would get a little less than half of that.
That's kind of a lot to mill, isn't it? I went with 20 thousandths so my compression should be 11.8:1 like VTECMAN. If you mill too much, it can adversely affect the timing and whatnot, right? Also the risk of piston/valve contact?
Thoughts?
FB
Old Jun 18, 2001 | 04:23 PM
X2BOARD's Avatar
If the head is milled correctly you will gain a few horses, but you will have to adjust your cam timing to compensate.. prolly retard the intake AND exhaust.... I would recommend looking into higher compression pistions rather than milling the head... The more you mill a head, the more likely you are to mill it beyond repair.. If you overheat, you can warp the head and then have to shave again. Leave the milling to the racecars...they can afford it for a few horses. Get B16A pistons... $300-$400 if you can afford it... they'll give you up to 1 compression point up on a GS-R.
Old Jun 18, 2001 | 08:29 PM
o_Rage_o's Avatar
I have a similar setup and was wondering how the headers felt after the install....lower end tourque??? Same question for the icebox...
thnkx.
Kzoorice
Nov 9, 2004 09:00 AM
Blaise
Oct 17, 2004 05:54 AM
Propulsion
Nov 24, 2003 09:16 AM
90da4dr
Mar 2, 2003 05:38 PM
