O2 sensor wire
Old Jun 20, 2001 | 07:55 PM
Flamenco-T's Avatar
Default O2 sensor wire
I have been trying to find out which one is the O2 sensor on the ECU so I can hook up my air/fuel ratio gauge...but all I got is synistic answer...
please one simple question, where do I tap my o2 sensor wire from the gauge to which wire on the P72 ECU (98 GS-R)
I tried to look up for wiring diagram on the net, but the one I found was blurry and couldn't tell which is which...
please...thank you
Old Jun 21, 2001 | 08:50 AM
Flamenco-T's Avatar
Default Re: O2 sensor wire (flamenco)
ttt
I am sure one of you guys has either a helms or has installed an a/f ratio gauge
Old Jun 21, 2001 | 09:19 AM
GTEater's Avatar
from autometer.com........
***96 and up Integras, including the following body styles: GS, GS-R, LS, and RS
For the most part, as with the Honda's, the O2 sensor signal wire will be a white wire, possibly w/ black stripe on it.
94-98 Integra 1.8L
Look for the computer of the vehicle or PCM. Go to pin D14 which is a solid white wire, or go directly to the sensor and tap into the white wire there.
when i connected the signal wire to the ECU it didn't work so i spliced into the O2 sensor wire (solid white wire)...i also heard the wire on the o2 sensor might give a more accurate reading...if you decide to go this way get wire t-taps from autozone.....this makes is a hella lot easier to splice into a wire
hope this helps
Old Jun 21, 2001 | 02:28 PM
Flamenco-T's Avatar
Default Re: O2 sensor wire (GTEater)
THANK you...
Old Jul 7, 2001 | 12:15 AM
keys's Avatar
does anyone know if this technique is the same for 90-93 integras??
hey the search function actually worked!! but this is the only exception
Old Jul 7, 2001 | 01:34 PM
keys's Avatar
Default Re: O2 sensor wire (keys)
anyone?
Old Jul 7, 2001 | 04:38 PM
Arturbo's Avatar
Better than steak
25 Year Member
Im pretty sure its the white one as well. It will thicker than any other wire...
art
[Modified by Arturbo, 8:38 PM 7/7/2001]
cbabyby
Jun 17, 2006 06:38 PM
accordianex
Feb 19, 2006 07:07 AM
JDMegCivic86
Oct 3, 2004 06:01 PM
Pele
Oct 11, 2002 10:57 PM
FusionITR
Feb 28, 2002 11:50 PM
