i have an abs problem?
Old Feb 27, 2011 | 07:54 PM
sergio0511's Avatar
Default i have an abs problem?
everytime its cold out side like below 25 degress mijoraty off the time i hear a wierd whinning noise from my front brakes and also the brake peddal pushes out... when its warm outside the abs is perfectly fine. anyone knows what the problem might be?
Old Feb 27, 2011 | 09:09 PM
el crapitan's Avatar
Default Re: i have an abs problem?
on a cold day, does the problem go away once the brakes heat up?
Old Feb 27, 2011 | 11:44 PM
sergio0511's Avatar
yes it goes away but den itll come an go rarely if the btakes r warm
Old Feb 28, 2011 | 12:11 AM
lazlong's Avatar
Originally Posted by sergio0511
...the brake peddal pushes out...
Do you mean it pulses or it's harder to push in? If it's harder to push in, replace the master cylinder.
Usually a whine from the brakes is the wear indicators telling you that it's time to change the pads.
Old Feb 28, 2011 | 03:07 AM
Dogginator's Avatar
Daisy... Daisy...
What year is your car? Is the ABS light ever illuminated? Check the wheel speed sensors for dirt.
Old Feb 28, 2011 | 08:30 AM
sergio0511's Avatar
its a 94 n the original cluste and abs lights isnt on.... n it gives a quick hard pulse n then i hear like wierd noise coming from the front first the d.s. den p.s.
Old Feb 28, 2011 | 09:14 AM
lazlong's Avatar
Sounds like a warped rotor. Could possibly be a sticking caliper. Does it pull to one side when it pulses?
Old Feb 28, 2011 | 09:42 AM
Dogginator's Avatar
Daisy... Daisy...
Sometimes the high pressure reservoir leaks and the motor will run to repressurize it.
nvynuke18
Honda Civic (2006 - 2015)
Apr 12, 2009 03:22 PM
eliasromero
Mar 16, 2007 04:57 PM
obiora
Sep 11, 2005 10:53 AM
wuhungsixxx
Jun 17, 2003 10:11 AM
