what are these bolt numbers? Lca
What are these bolt part numbers or name when i search it alot of parts come so id like to be sure on what they are before i order them for Online.
just wondering are these it?
90172-SK7-A01 BOLT, DAMPER (LOWER) (10X84) 1998 INTEGRA
90173-SR3-003 BOLT, ARM TORQUE (LOWER) (10X80) 1998 INTEGRA
[IMG][/IMG]
[IMG][/IMG]
Re: what are these bolt numbers? Lca
why order them? Is their any reason you need them brand new? you should be able to find any of those bolts at a local pick-in-pull.
I'd probably order them new. Maybe the OP doesn't have a "pick-n-pull" near by, or maybe he doesn't have the time to try to go find used ones. To me it would be worth the time savings to just order new ones.
true, i was just throwing it out there to help maybe save him a few bucks.
Alright i got the right side bolt but the middle bolt i dont seem to find the middle and cant find out where it screws on to.
Protip:
Do the middle one first (the one that connects to the shock) then do the end one.
Problem you're having is the holes are misaligned on the center one.
I usually bolt up the shock fork bolt, then use a jack to raise the LCA into place, and then work the trailing arm so that it lines up with the outer hole. Sometimes it can be a PITA but eventually it lines up and the bolt goes in.
