abs light is on.
Old Feb 27, 2011 | 04:44 PM
jeffrox626's Avatar
Icon2 abs light is on.
i have a integra gsr 95' and i think ther is something wrong with my abs..
everytime i start my car ther is a loud sound coming from my abs module andthe sound last for at least 2mins durning that 2mins...wenever i step on the brake pedal the sound becomes louder and i can feel the brake pedal becomes very stiff...after the 2mins my abs light comes on.
any ideas how to fix it?
Old Feb 27, 2011 | 09:02 PM
el crapitan's Avatar
Default Re: abs light is on.
pull the codes from the module
Old Feb 27, 2011 | 09:39 PM
mark@silbernage's Avatar
Do any brake work recently? I agree, pull the codes is the right first step.
I ask about brake work because air in the system can do this... as one example.
Given your description, one code may be ABS motor over run - which means it runs until timeout without reaching pressure; air in the system would be one cause of many (potentially).
Good luck
Old Feb 27, 2011 | 10:36 PM
jeffrox626's Avatar
Good luck
i actually bought the car last summer and i havent did a brake change or anything since my brake pads still have alot of meat. how would i fix the problem? do i just bleed out the brake fluid?
Old Feb 27, 2011 | 11:40 PM
Well, first, I'd get the codes. Really.
But on that ABS it's fairly easy to bleed. Have you checked the fluid level?
Old Feb 28, 2011 | 07:00 AM
jeffrox626's Avatar
how do i get the codes? lol
i will check that asap
Old Feb 28, 2011 | 01:30 PM
Jwinnd88's Avatar
On the thread page for integras, at the top there is a how to thread dealing with ecu and abs lights, and how to pull codes. Good luck.
Old Feb 28, 2011 | 01:48 PM
95_B18b1_Teg's Avatar
mine was doing the same thing, it was like a loud buzzing noise coming from the passenger side of my gsr, i just pullled the black tab off of the white abs box, pulled out the plastic top and topped it off with brake fluid and it stopped
Old Feb 28, 2011 | 02:38 PM
jeffrox626's Avatar
hot dog! it worked my abs doesnt make the sound anymore and abs light is off haha
Old Mar 1, 2011 | 03:09 PM
question is though; why was it low?
Old Mar 1, 2011 | 04:42 PM
jeffrox626's Avatar
i dnt have a clue....when i bought the car it was basically sitting there. the previous owner didnt drive it for a while and i basically renew everything.
Old Mar 5, 2011 | 09:22 AM
Nicolee's Avatar
I think this is pretty common with the abs systems. I'm sure your fluid was low and it probably has a mild leak. Not really a big deal considering the price of the part is much greater than the actual, relatively small, problem.
Old Mar 5, 2011 | 11:20 AM
fastrxu's Avatar
How do u bleed the abs module? Its my first teg with abs and I saw the abs module has a bleed valve....how do u bleed it?
herrgolf
Jul 22, 2008 12:11 PM
kjmoy
Dec 10, 2007 02:38 AM
