Problem while swapping out ignition coil
Old Mar 1, 2011 | 08:31 AM
w211 ryda's Avatar
Default Problem while swapping out ignition coil
So I was attempting to remove my ignition coil last night, but I ended up marring one of the ignition screws (see picture of example). Can’t believe how delicate these screws are…so easy to mess up the heads! Anyhow, can I just replace these screws with any regular screw or does it have to be one of those special diamagnetic screws?
Old Mar 1, 2011 | 04:00 PM
fonkernuckle's Avatar
Default Re: Problem while swapping out ignition coil
Sounds like you are not close to the dealership or need your car running to get there. I would do one of the following 2 if you can't get to the dealership for replacement screws: Use a screw of same thread size and go for it (its just a screw to hold the wire in place-its all one connection) or lock some vise grips on the screw and cut a slot on the head with a dremel and reuse. just my 2 cents-no flaming necessary
Jeremy Dunn
Jun 20, 2017 11:49 AM
Tuneman1984
Jun 5, 2013 08:15 PM
LS94tegra
Dec 4, 2007 08:40 AM
SuperDuude
Jul 3, 2004 06:38 PM
Utilitarian
Jul 14, 2003 04:53 AM
