Integra Code 6 ECT
Old Mar 3, 2011 | 09:55 PM
DC2R96's Avatar
Default Integra Code 6 ECT
The only code i'm getting is the ECT and my car won't start ... i'm going to replace the sensor but does anyone know if this really is the problem .. can the ECT prevent the car from starting ?? I'm going from OBD1 to OBD2a .. From a B18b to the JDM b18c do I have to replace all the JDM sensors is that why it's not working ... i'm using the JDM computer so ??
There are a couple of ECT .. the switch, the sending unit, and I think one more which one messes with the A/F??? I know the sending unit tells the gauge what temperature things are at ... so is it the switch??
Old Mar 4, 2011 | 05:30 AM
Murk 'EM's Avatar
Default Re: Integra Code 6 ECT
It can mess up the a/f ratio causing a no start
Old Mar 4, 2011 | 05:35 AM
1998GsRIntegra's Avatar
Short answer yes it can prevent your car from starting. Replace it.
Old Mar 4, 2011 | 05:43 AM
dpetro1's Avatar
yes code 6 can prevent the car from starting. make sure the plug is connected tightly and look for an loose/frayed wires. make sure your coolant is full and bled of any air pockets
Old Mar 4, 2011 | 03:23 PM
DC2R96's Avatar
yea but the car has to start first ... I did a power and ground check at the injector plug and i'm getting both .. put a noid light in the plug and when I turn the car over NO PULSE .. would the ECT stop the injectors from getting pulse??
93egtypeR
24
Aug 5, 2010 01:04 PM
moonjaw2002
Classic Hondas
Nov 25, 2007 06:46 AM
jdm94h22acivic
May 14, 2003 04:01 AM
crx_91si
Jan 22, 2002 05:06 PM
