Alignment Issue
Old Mar 1, 2011 | 09:54 AM
mattyfo0z's Avatar
Default Alignment Issue
So I just got some new wheels tires about a week ago and I just was able to get an alignment done yesterday.
When I put the new wheels/tires on, the car pulled a little to the right so I new that it definitely did need an alignment. Previously, I had steelies with hubcaps and the car drove straight with no problem.
Now after the alignment, my car pulls to the right significantly worse. Nothing too intense, but no doubt more than it was before the alignment.
I called about 15 minutes ago, and the guy said it's most likely something wrong with my car because it's lowered and it suggested things like motor mounts, or something else.
I took a picture of the scanout, so I can get some suggestions. Is there anything wrong with the way they have my suspension setup? Thanks for any insight
Old Mar 1, 2011 | 09:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Alignment Issue
Please take another picture in better light, with macro setting on if you have a point-n-shoot camera (little flower symbol on most of them). I can't make out most of that printout at all, especially the rear wheel readings.
Old Mar 1, 2011 | 10:26 AM
mattyfo0z's Avatar
Sorry about that, my camera phone's not the best...
http://img853.imageshack.us/img853/3874/16487831.jpg
http://img849.imageshack.us/img849/3689/88129975.jpg
http://img195.imageshack.us/img195/1253/73128673.jpg
http://img195.imageshack.us/img195/2498/73260739.jpg
http://img215.imageshack.us/img215/5372/42583883.jpg
Old Mar 1, 2011 | 07:24 PM
mattyfo0z's Avatar
ttt
Old Mar 1, 2011 | 08:10 PM
MD426's Avatar
It doesn't make sense that they didn't zero or match each toe for the front and rears, even if they are in acceptable range they should atleast be the same in my opinion. Try switching the front tires if it pulls to the other side it might be a tire, if the side wall construction is off it will not roll straight. Lowering the car shouldn't make much of a difference.
Old Mar 1, 2011 | 10:38 PM
sirlaughsalot's Avatar
The only thing I don't like about the alignment would be your camber difference from front to rear. The toe angles were more than acceptable, if not excellent to compensate for the driver.
It would have just been easier if you just typed it all out instead of having a ton of pictures though, kind of irritating.
The front to rear bias for camber angles should be something between .5-1.0 degree difference with the front angle more negative than the rear.
Old Mar 1, 2011 | 11:51 PM
Scooooter7's Avatar
If being lowered is a problem did they tell you that BEFORE they tried to align it?
Old Mar 2, 2011 | 02:05 AM
MUACHi's Avatar
shoot! i have the same problem right now. i just swapped my stockies with 205/60/15 for some buddyclub p1 racing 205/50/15 and now my car is steering off to the left badly. gosh i know i need an alignment but damn!!!! this is ridiculous i was hoping it was the tire pressure but after checking them out still no fix. im debating whether i should get an alignment or not, dont wanna do it unless it fixes the problem, fyi its stock height too
Old Mar 2, 2011 | 03:28 AM
mattyfo0z's Avatar
He only told me that when I called yesterday, not during me actually getting the alignment.
Old Mar 2, 2011 | 06:04 AM
KILLAB17VTEC's Avatar
Genetically Gay
hope u get that fix..i remember when i had a bad alignment on one of my cars my steering was going sideway and the car was pulling to the right the same time..i was ridein like that for awhile til i can afford a aligment..crazy
Old Mar 2, 2011 | 04:53 PM
mattyfo0z's Avatar
ttt
Old Mar 2, 2011 | 05:51 PM
MD426's Avatar
ttt
Did you try moving the tires around to see if the car pulls differently?
Old Mar 3, 2011 | 03:45 AM
Dogginator's Avatar
Daisy... Daisy...
What wheels and tires are you running? Please list the sizes.
Old Mar 3, 2011 | 09:45 AM
mattyfo0z's Avatar
They're 15" Drag wheels, similar to Rota Boosts. Probably 15x6.5 with a regular offset. Tires are Falken ZIEXs 195/50/15s.
mattyfo0z's Avatar
I'm going to be doing that this evening, I got out of work late yesterday and had loads of homework to finish for my classes today
Old Mar 3, 2011 | 10:10 AM
Dogginator's Avatar
Daisy... Daisy...
Check the ball joints and tie rods while you have the car in the air.
Old Mar 3, 2011 | 10:34 AM
mattyfo0z's Avatar
Will do.
Thanks for the help so far guys
mattyfo0z
Suspension & Brakes
Mar 1, 2011 09:07 PM
evosix
Suspension & Brakes
May 22, 2009 06:42 AM
integra_type-r
Nov 1, 2006 06:33 PM
fabalus206
Oct 1, 2006 01:58 PM
2001civ
Jan 12, 2003 09:50 AM
