starting prob
Old Feb 22, 2011 | 05:57 PM
turbo gsr2000's Avatar
Default starting prob
so i have a 00 dc2 with fully built bottom block 2.0l and the car will start right up but when i drive it for a little when i turn it off... it hard to start just keep's cranking let it sit then after a while it will start and idea??
Old Feb 22, 2011 | 06:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: starting prob
Have you checked to see if the problem is no fuel or no spark yet?
Fuel Pumps, PGM-FI Main Relays, Ignition Coils and ICMs, [ignition control module or igniter] are all susceptible to heat failure.
Start with the basics, fuel/spark, good consistent fuel pressure/strong consistent spark, do you have them? 94
Old Feb 22, 2011 | 11:27 PM
james626's Avatar
your car could be dumping too much fuel and the sparks cant keep it, this happened to my friends car before.
Old Feb 23, 2011 | 04:33 AM
1998GsRIntegra's Avatar
This^^^ Either the coil or icm is my guess because of heat failure.
Old Feb 25, 2011 | 08:40 PM
just put a new dizzy on the car and it still doing the same **** going to change the fuel filter 2marrow
ev94eg
15
Jun 7, 2011 04:39 AM
boosted423
Aug 4, 2008 08:20 PM
hayn_integra
Oct 23, 2007 10:09 AM
pbizzlegsr
Aug 27, 2004 08:55 AM
