help with cluster
Old Feb 26, 2011 | 01:04 PM
14baldo66's Avatar
Default help with cluster
so i have a obd2a LS cluster and a obd2b GSR cluster, gsr cluster went bad so i swap allllll the gauges into the LS cluster, everything looks like it worked good minus the speedo. wen i turn on car it jumps to about 50mph n chills there, wen i turn off car needle drops to where it shud b. does n e one know y it does this?
Old Feb 26, 2011 | 01:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: help with cluster
Check you cluster ground(s). 94
Old Feb 26, 2011 | 02:09 PM
14baldo66's Avatar
How wud i check? Is it the screw for the speedo section that says GND? Cuz i unscrewed n screwed it back n same thing jumps to 50 exact
Old Feb 27, 2011 | 07:59 AM
14baldo66's Avatar
Bump
Old Feb 27, 2011 | 12:34 PM
14baldo66's Avatar
so i was lookin at my pig tails from my obd2b gsr harness and sum wires r in different loctions than the obd2a pigtails from the LS. is this y the speedo stays at 50mph at a stop?
another question, how do i check if my TPS sensor is n e good? and which years and models can i use TPS from for my teg
Old Feb 27, 2011 | 10:19 PM
14baldo66's Avatar
Bump......
Old Feb 28, 2011 | 04:07 PM
14baldo66's Avatar
bump......wud this have n e thing to do with my VSS? took my car up n down my alley, tags expired, and it response weird. in first gear, from about 1k-2k rpm the car feels like ****, feels like its at 50% power, not till pass 2k does the car pick up strong. n e clues?? my car is a mess =( all this **** happened outta no where
Old Feb 28, 2011 | 06:54 PM
fcm's Avatar
fcm
Old Fart
What is the MM&Y of the car?
What is the MM&Y of the car the engine is from, if not the same as above?
What is the MM&Y of the cars the two clusters are from?
Until I know the above I can not look at wiring diagrams.
Interfacing different OBDs is always going to be problematic, as you can see by the difference in the two cluster harnesses, without seeing wiring diagrams I can't tell exactly what the problem is, but VSS is definitely a possibility, the speedometer may not be calibrated to the VSS, or the VSS itself is bad.
Are there any codes? 94
Old Feb 28, 2011 | 08:46 PM
14baldo66's Avatar
Car 97 LS, engine 2000 B18C1. Im comparing the pigtails from 97 LS to 2000 GSR. i changed all the gauges from the 00 gsr cluster into the 97 LS cluster. so im still using LS cluster, just with gsr gauges. If i swap my whole complete ecu harness with harness from my 00 gsr will it all clip up? I know ima need different ecu, 97 being obd2a and 00 gsr being obd2b. I just dnt wanna tear it apart n it not clip up right. I also wanna do this because other issues im having that i belive is do to a bad ecu harness. I do have cel's but idk i dnt believe they r real. I have one for crank sensor, number 1 cylinder position, knock sensor. Ive already bought new dizzy and another sensor that it said needed to b changed. Never had these issues till 3 months after i swapped motor into 97 Ls
Old Mar 1, 2011 | 09:52 AM
14baldo66's Avatar
ok so the harness r different, n e one got a 96-98 ecu harness for sale or trade? lmk ppl thanks
Old Mar 1, 2011 | 10:12 AM
fcm's Avatar
fcm
Old Fart
Check your local PicknPull, there ar 20 locations in CA... http://www.picknpull.com/ 94
Old Mar 1, 2011 | 11:12 AM
14baldo66's Avatar
true
ronintegra
Jan 3, 2006 12:10 PM
iTzKeviN
Sep 6, 2005 02:28 PM
_HANS
Dec 25, 2004 11:22 AM
gulftools
Apr 8, 2003 11:21 PM
