HID Problem on JDM Conversion! Need HELP!!!
Old Feb 22, 2011 | 11:19 PM
Matt2458's Avatar
Default HID Problem on JDM Conversion! Need HELP!!!
Okay. So here's the problem
I have a JDM front GS-R. Running a HID setup. The other night while driving the HID's flickered (I turned them off, and turned back on). They worked for about 5 minutes then flickered again. I turned them off once again and then they didn't come back on.
Here's what I've concluded after some time checking it out:
HIDs work when brights are off. After flickering brights both positive and negative sides of the HID plug read 12 volts. And HIDs no longer work. No blown fuses. New relay. Relay turns on and clicks. Ground wires are connected. Grounded correctly. Ballasts are working correctly.
I really honestly don't know what there is left to do and if anyone has had this problem or knows what is wrong any help or advice would be great. Thanks.
Old Feb 22, 2011 | 11:23 PM
james626's Avatar
Default Re: HID Problem on JDM Conversion! Need HELP!!!
did you check the bulbs? most likely the ballast is bad cause mine started to flicker and i switched out the ballast and it was fine.
Old Feb 22, 2011 | 11:29 PM
Marcin_519's Avatar
i would say same ballast went bad had that problem before check maybe there is corosion in the plugs sometimes water gets in there good luck
Old Feb 23, 2011 | 02:16 AM
ElementzofR's Avatar
either bad ballasts or bad bulbs
Old Feb 23, 2011 | 04:35 AM
1998GsRIntegra's Avatar
Bad ballast, bad bulb, or a combination of the two.
Old Feb 23, 2011 | 07:21 AM
EJ6JON's Avatar
Its most likely bad ballest bad bulbs wouldnt make it flicker it wouldnt work at all change the ballast and you will be good this has happened to be before
Old Feb 23, 2011 | 07:34 AM
Matt2458's Avatar
Well that's what I'm saying. It's not the ballasts because they eventually worked. They are working like every other time we plug them in.
Old Feb 23, 2011 | 05:03 PM
jaqattack02's Avatar
The ballast might be on the way out. Are you sure they are getting enough power? I know HIDs require a good bit of power, especially when they are firing up. If you do not have heavy enough gauge wiring to them they can have trouble drawing enough power and it's bad for the ballast. I believe it can also cause the ballast to get too hot, but i'm not positive. That could explain why they came back for you, the ballast could have cooled down.
It's also bad for them if you have your HID lights on when starting the car. The starter running causes all kinds of disruption in the power system, and draws a good bit of power, and it's really hard on the ballast as well. Either of those things can cause the ballast to start giving out.
malubawla
Aug 10, 2006 11:17 PM
Devine
Nov 28, 2005 02:31 PM
Irish Integra
Jun 10, 2005 06:46 PM
b18bEG
30
Dec 13, 2004 05:26 PM
