map sensor problem
Old Mar 2, 2011 | 08:33 PM
Marcin_519's Avatar
Default map sensor problem
hey guys i have a problem with map sensor i have 96 integra with obd2 b20 motor i couldnt find obd 2 wireing and my old one got meleted due a fire so i grabed obd1 civic wireing and convereted distributor and injectors the wireing cam form civic that the map sensor was on the fire wall so i took map sensor conector form my old wireing and pined it to the obd1 wireing the way it was in my original wireing. now the car wont run with map sensor pluged in but if i disconect it it runs but back fires jerks and have no power at low rpm
i checked wires form plug all the way to ecu seems fine i have no idea whats wrong with it at first it ran good but then started to have no power can somone help me i have no idea whats wrong with it i tried everythin and now im sick of itt please helppp
Old Mar 2, 2011 | 09:14 PM
mouab18c1's Avatar
Default Re: map sensor problem
Did you wire it right?
Old Mar 2, 2011 | 09:56 PM
Marcin_519's Avatar
yes the way it was in my old wireing and i checked online the pins on ecu used tester light form plug all the way to ecu and it lighted up i have no idea whats wrong does anyone have diagram for it maybe i screwed something up >
Old Mar 3, 2011 | 06:15 PM
Marcin_519's Avatar
bump i need help everytime i post something here no one ever help me
Old Mar 3, 2011 | 06:33 PM
mouab18c1's Avatar
NO cel or anything?
Old Mar 3, 2011 | 06:39 PM
el crapitan's Avatar
MAP and TPS connector switched?
Old Mar 4, 2011 | 10:16 AM
Marcin_519's Avatar
no i dont have em switched becuause the harness came of a civic that had map sensor on fire wall and i just pined the map sensor in just the way it was in my obd2 harnes now wont start with it
cel ye map sensor ant o2 sensors
Old Mar 4, 2011 | 02:46 PM
there are 2 map sensor codes available. mechanical and electrical. what is the exact code #?
Old Mar 5, 2011 | 07:30 AM
Marcin_519's Avatar
imnot sure i will let you know tonight igotta check it again
gizmogwaii
Sep 24, 2016 11:55 AM
Dc_Ek
Feb 13, 2013 11:47 PM
97EKCRVtec
Aug 18, 2009 11:36 AM
Del Sol on Steroids
Nov 22, 2006 12:50 PM
