2.25 Magnaflow Oval - Resonator or No Resonator?
Guest
Posts: n/a
I have a Magnaflow 2.25" oval muffler on an Apex'I Dunk Cat-back minus the Dunk muffler, 2.25" straight pipe, and DC headers on a H22. Currently, it has a buzzing annoying sound at around 2000-3000rpm and 4000rpm-up.
Now my questions are:
If I get a 2.5" Magnaflow oval muffler, would it be deeper? or buzzier? or louder?
If I get a resonator put on, Will that buzzing noise go away?
Any other advice? What's better? Magnaflow or ES oval? Whats quieter? whats the difference?
Re: 2.25 Magnaflow Oval - Resonator or No Resonator? (ophdeheezy)
I'm suprised that the Apexi Dunk's resonator doesn't take that buzzing sound away. You might want to try a longer resonator.
Also, are you sure the sound isn't a rattling sound that may be caused by the heat shields.
<<< facing that "buzzing" noise right now.. hoping resonator will fix that.. and from what people have told me (one this board, sorry couldn't find my post *lazy*) a resonator will make it really clean sounding compared to what you have right now and buzzing will go away (I'm hoping at least ) hehe
Re: (Heisdan)
the buzzing could be coming from a number of things:
1) a clogged/half blown through cat (only if you have higher miles)
2) heat shields - just take them off, even the one on the cat
3) a rusted through resonator on the B-pipe (hard to tell)
4) a buzzy muffler
5) an older muffler that is starting to rust out
Good Luck.
4) a buzzy muffler
Good Luck.
Re: (jabroni95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabroni95gsr »</TD></TR><TR><TD CLASS="quote">the buzzing could be coming from a number of things:
4) a buzzy muffler
Good Luck.</TD></TR></TABLE>
very true.. so many factors go into why a car sounds the way it does. makes it hard when ppl ask: what your system sound like? well depending on those factors and if your running a testpipe, cat, gutted cat, all are factors: size of piping, turbo or NA
4) a buzzy muffler
DRKSol
01-06-2004 10:28 AM
