Ignition Help
Did you check your battery voltage? The water level? Are the terminals corroded? (If so bad cable/ground might cause it) I'd take it to Schucks and get it tested. They'll be able to tell if your alternator and battery is good/bad. It could be your starter too.
uNF$@#!
Jan 8, 2021 08:31 PM
honda.girl.1991
Oct 23, 2013 06:53 AM
